Page 5 of 8
Re: how i fixed the problem.
Posted: 30 Aug 2022, 03:04
by assombrosso
Also, what games u play ? And what’s the difference in terms of KDR and how many multi kills and headshots you make ? In my case, when my system performed “better” my KDR goes wayy up and winning games becomes unreasonably easy. I would need the details of the change if you can shed more light into it, will be great.
Posted: 01 Sep 2022, 06:35
by woodyfly
u should make a tutorial on how to set up everything. if youve truly fixed it, you are basically a pioneer in this issue as nobody has really ever fixed it. I dont think anyones tried solar panels like you did
Posted: 05 Sep 2022, 09:06
by lyar
woodyfly wrote: ↑01 Sep 2022, 06:35
+1
Posted: 05 Sep 2022, 16:36
lyar wrote: ↑05 Sep 2022, 09:06
+1
It'll only help a few people, but a few success reports have already been posted here by going offgrid (power stations, solar) in earlier threads.
The problem is the solution unique per person.
No two interefrence problems are perfectly identical, much like no two snowflakes are identical.
A univeral HOWTO, is thus impossible, and one can only attempt generalities that has better odds of fixing things.
Posted: 22 Sep 2022, 03:52
by calamity5555
Hello Texre,
Glad you solved the issue for yourself. I'm looking to try a custom made power station with battery/inverter from a local provided in BC.
Since you're based in SoCal, have you tried playing Fortnite matches at localhost in Fullerton?
https://goo.gl/maps/snyQBcH8q4VziMRt6
I have the same issue but I can't seem to get responsive, smooth, and accurate gameplay at any of the localhosts for tournaments.
However, I've heard good things about localhost Denver.
If you have time for the next 3 months, do you mind playing at localhost Fullerton for a bit to see if it's the same as a fixed setup.
Posted: 28 Sep 2022, 08:29
by wadge
calamity5555 wrote: ↑22 Sep 2022, 03:52
Hello Texre,
Give us any update when you tried the combo inverter (better be pure sine wave) and battery
Posted: 02 Oct 2022, 13:13
by texre
wadge wrote: ↑28 Sep 2022, 08:29
Hello Texre,
Fullerton is about 40 mins from me
Posted: 02 Oct 2022, 13:19
by texre
Hello Texre,
Some interesting findings, after a few months of testing. It still works great I love gaming again I don’t rage at all anymore gaming sessions are so much more enjoyable it’s perfect. Soo about charging the station with electricity, Ik chief said electricity can’t be stored but it can. I charged with my bad electricity the gameplay becomes so bad. After I use all bad energy and charge only with solar it goes back to being really good. So it definitely can be stored. So I don’t think your inverter power station will work sadly. Only thing that works is solar for right now.
Posted: 02 Oct 2022, 13:21
by texre
Can electricity be infected ? It’s not interference because I don’t play while it’s charging so it has to be like a bad energy source or something who knows
Posted: 02 Oct 2022, 13:42
by akylen
texre wrote: ↑02 Oct 2022, 13:21
Could you do a little tour with pictures of your setup/electricity setup to give us a view of what it looks like ?
