The link is dead now, what happened to that script? Does it still work/worth trying? If anyone have it by any chance, please share.Anonymous wrote: ↑30 Jun 2023, 10:05It's done.
https://github.com/Anonymous/gaming_os_tw ... on_usb.ps1
(INTEL ONLY) An easy way to instantly lower input latency
RealTweaker
Re: (INTEL ONLY) An easy way to instantly lower input latency
sherifmagdy32
l
RealTweaker
Thanks, but is this Intel only? I was replying to a guy who made a working script for amd, but the link is dead nowsherifmagdy32 wrote: ↑13 Feb 2024, 20:26https://github.com/amitxv/PC-Tuning/blo ... ation-imodRealTweaker wrote: ↑11 Feb 2024, 00:36The link is dead now, what happened to that script? Does it still work/worth trying? If anyone have it by any chance, please share.Anonymous wrote: ↑30 Jun 2023, 10:05It's done.
RealTweaker
Found this also:
- viewtopic.php?f=10&t=12250&start=10#p96042I found an alternative tool to RW and HE, that is just a command line tool and I replaced RW in the imod script, should work out of the box in any OS without needing to do anything.
- Espionage724
Auto-start on log-in:
Code: Select all
SCHTASKS /Create /SC "ONLOGON" /TN "XHCI IMOD" /TR "'%ProgramFiles%\RW-Everything\Rw.exe' /Min /NoLogo /Stdout /Command='W32 0xC1222024 0x00000000'" /F-
Hyote
The correct script:
https://github.com/valleyofdoom/PC-Tuni ... terval.ps1
This is needed for Windows 11:
reg add "HKLM\SYSTEM\CurrentControlSet\Control\CI\Config" /v "VulnerableDriverBlocklistEnable" /t REG_DWORD /d "0" /f
Also, just move the .ps1 script into shell:startup
