Page 5 of 15
Re: ULMB 2 Released
Posted: 31 May 2023, 16:11
by Shing0
Has anybody tried large vertical total through QFT on ULMB2 supported monitors ?
Re: ULMB 2 Released
Posted: 31 May 2023, 21:51
by lyrill
30 May 2023, 03:18
Make sure you use very fast speeds like 3000 pixels/sec when testing pulse width differences.
My favorite TestUFO for strobe pulse width experiments is /map#pps=3000 and then maximize to full screen mode (but make sure you're using VSYNC ON for full screen mode in NVCP)
I like that one because it goes blurry at 1ms MPRT and goes sharp at 0.5ms MPRT, great demo of the need for sub-1ms MPRT.
i've got wt on background and 2880 is already near impossible to read. still on the 390hz
Re: ULMB 2 Released
Posted: 01 Jun 2023, 14:36
by bumbeen
Working on this!! After 45 minutes trying I have one good image and a newfound respect for you folks out here doing this on the daily. Oh my lawd this is at least 10x more difficult than I was expecting. So I used my Sony a7c for those images above. And the one good image I got was on my sony G 20mm prime. I believe I have video off the sony as well but I have to get it loaded and poke at it in resolve to try and see if there's any worthwhile frames in there. If I have to I will break out the gimbal, haven't had an excuse to use that thing in a hot minute.
Re: ULMB 2 Released
Posted: 02 Jun 2023, 03:39
lyrill wrote: ↑
31 May 2023, 21:51
0.5ms MPRT(0->100%) is only 1 pixel of motion blur at 2000 pixels/sec.
The motion speed is right at the threshold of human eyetrack abilities for 1080p just to read ONE label (especially if you first pause the map and study a street label to aim your eyes at during motion test -- like labels near Toronto's "Skydome", erm, "Rogers Centre").
0.5ms vs 1.0ms MPRT is easier to tell apart at 1440p or 4K.
Nontheless, 0.5ms versus 1ms MPRT human-visibility tests requires extreme motion speeds.
Even easier is 4x motion blur blur differentials (e.g. 0.25ms MPRT versus 1.0ms MPRT), on an 8K display. At 4000 pixels/sec, which takes almost 2 seconds to go horizontally across the screen, that's enough time to tell apart spatial versus motion resolution. That's 1 pixels of motion blur versus 4 pixels of motion blur.
Re: ULMB 2 Released
Posted: 04 Jun 2023, 20:59
by lyrill
02 Jun 2023, 03:39
lyrill wrote: ↑
31 May 2023, 21:51
yeah definitely can easily tell diff of 200 400 600 fps even on this budget "360 panel" so i guess the question is, still wait for 2x rule or cop on this? cus i really need a new pc for these.....and 1440p+ obv..
Re: ULMB 2 Released
Posted: 06 Jun 2023, 22:40
by akrios
Been going back and forth lately between G-Sync and ULMB 2 trying to decide what I like more, the extra clarity during motion or the consistent smoothness with G-Sync. I get around 200-220fps a lot in Apex when not capped at 300fps in 1440p.
Re: ULMB 2 Released
Posted: 08 Jun 2023, 01:44
by Blurnabi
Does DLSS3 framegen have ability to run vsynced for consistent frame delivery? I mean there are only handful of new games which can run consistent 360fps with top spec PC let alone 160fps therefore having ULMB2 with native 360Hz is kinda moot. I even have trouble running consistent 240Hz on my most played game Dota2 no matter what the settings I use with 4090 GPU and 7600x.
I feel like there are lots of avenues to explore with strobing and frame generation interoperability.
Re: ULMB 2 Released
Posted: 08 Jun 2023, 11:05
by RealNC
Blurnabi wrote: ↑
08 Jun 2023, 01:44
Yes. Initially, neither vsync nor gsync were supported. Now both are working.
Re: ULMB 2 Released
Posted: 08 Jun 2023, 11:54
by Kuscheln_Hammer92
akrios wrote: ↑
06 Jun 2023, 22:40
Does ULMB 2 run with anything else on say RTss scanline sync or if you have fast sync on and framerate uncapped?
Re: ULMB 2 Released
Posted: 08 Jun 2023, 17:49
by bumbeen
Kuscheln_Hammer92 wrote: ↑
08 Jun 2023, 11:54
akrios wrote: ↑
06 Jun 2023, 22:40
yes. the strobing is solely a function of backlight sync with a fixed monitor refresh rate, there is no awareness of game FPS or other syncing function
