About my settings for computer optimization
Hyote
Re: About my settings for computer optimization
Post by Hyote » 17 Jan 2025, 16:25
alp15eren wrote:
17 Jan 2025, 06:49
JimCarry wrote:
16 Jan 2025, 19:19
alp15eren wrote:
16 Jan 2025, 11:40
JimCarry wrote:
16 Jan 2025, 10:47
can you tell me in your opinion on what core shoud i put my gpu and ethernet.
Play a game with high fps, move your mouse as much as you can and download any files in the background. (For example Valorant. Enter the training area but do not enable bots.
While doing this, go to the CPUs page in the Latencymon program. Select the cores with the lowest 2 interrupt cycle times as GPU and Ethernet respectively.
Change the Go Interrupt Policy value for GPU and the RssBaseCpu value for Ethernet.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Ndis\Parameters
Create a new dword (32 bit) RssBaseCpu and enter the number of cores.
thanks there is many videos on how to set afinities.i will try it.
The ones in the Youtube videos are incomplete or give wrong information. GPU + Change the PCI EXPRESS port that the GPU is connected to. Leave the Ethernet as default and change it with RssBaseCpu via regedit.
If you do not change the PCI EXPRESS port to which the GPU is connected, you will get worse performance.
This info should be pinned or highlighted somehow.
JimCarry
Post by JimCarry » 18 Jan 2025, 08:45
Hyote wrote:
17 Jan 2025, 16:25
alp15eren wrote:
17 Jan 2025, 06:49
JimCarry wrote:
16 Jan 2025, 19:19
alp15eren wrote:
16 Jan 2025, 11:40
This is not the first time i see someone saying that if you do afinities for gpu you must do the port aswell i will put sources at least two, this is at least the 4th time i see someone saying it.
source #1 https://www.xbitlabs.com/how-to-use-int ... licy-tool/
alp15eren
Post by alp15eren » 19 Jan 2025, 14:36
JimCarry wrote:
18 Jan 2025, 08:45
Hyote wrote:
17 Jan 2025, 16:25
alp15eren wrote:
17 Jan 2025, 06:49
JimCarry wrote:
16 Jan 2025, 19:19
I saw these sources too. I think they are right. I only had fps problems when I did it to the graphics card. I can confirm on 2 different devices.
Post by Slender » 23 Jan 2025, 00:13
JimCarry wrote:
18 Jan 2025, 08:45
Hyote wrote:
17 Jan 2025, 16:25
alp15eren wrote:
17 Jan 2025, 06:49
JimCarry wrote:
16 Jan 2025, 19:19
you need do that only if Native Pci Power Management enable in bios (it gives msi mode on port)
