BEST WISHES EVERYBODY AND CS LAGG 7 YEARS
MK92
Re: BEST WISHES EVERYBODY AND CS LAGG 7 YEARS
More bullshit BIOS settings that should not be tempted with, because default factory settings are okay in 99% of cases if you don't overclock or do any weird shit.
Again, "250 hz feeling like 60hz" is the most typical symptom of insufficient electricity problem, and not hardware...+12V rail on GPU is not getting clean electrcity, and then it turns on error-correction protocol to prevent a shutdown, and you perceive this as a very low refresh rate.
You said that if you remove your GPU and re-insert it, it works normal for some time again...the only explanation for this is that everytime you remove the GPU, its capacitors are fully discharged of stray electricity...it will then work fine for 5 minutes, or 30 minutes, or 2 hours...who knows, but the problem is NOT some random obscure BIOS setting, so don't bother playing with that as you won't fix anything, you will just mess up the PC even more.
Sz3ypy
at this moment i use Intel 12700k plus rtx 5070 but i just start looking on AMD and i try collect some.info becouse i never Has AMDkyube wrote: ↑02 Jan 2026, 11:44Agreed, also a good option to do (which I forgot to mention at time of writing)dervu wrote: ↑01 Jan 2026, 10:57It costs much less to just rule out interference than you mention, just ask some friend or whoever you know to check it at their place or just go to some LAN and compare with other peoples game.
If it doesn't help, it costed you almost nothing, but some time to move it there and back and just LAN ticket.
Of course it shouldn't be first thing to try, but rather something that you do when you exhaust basic things.
Increased CPU overhead from more USB devices.
KB+M on USB is 'ideal' (the 'best' we can do with current hardware limitations when chasing lowest latency possible)
I don't know which port or which driver you should use, I haven't had the time to re-do my XHCI controller testing yet.
Sticking to default Microsoft ones for now is likely the 'safest' option.
Start by telling us what your UEFI settings are.valhalla wrote: ↑01 Jan 2026, 12:46Guys be Nice please thanks everybody for helping. Like what I say the first boot after installing Windows first launch cs2 and the mouse is good. * also iff i remove the gpu … boot up Windows , turn computer of putt the gpu back in its smooth again first launch. !!!!!!!!!!! It feels like Thérè is a transparant Windows over that is set to 60hz …..!!!!!!!!!!!!!! like an overlay . But i already disabled Xbox and i already tryd fullscreen etc anybody maybe has an idee ??? Maybe an overlay that I forgot ??? I think i dont have other programs with overlays .. clean window install I mean how can it be good everytime on first Launch
Send a screenshot of your current RAM profile will also be beneficial.
I suggest disabling the ALC4080 from your motherboard in UEFI & using the 3.5mm output of your XL2566X+.
Wired only peripherals, don't use a USB microphone.
Refer to: viewtopic.php?t=11081&start=70#p120791
- naporitan
This topic is complete nonsense.valhalla wrote: ↑31 Dec 2025, 10:04Broken scaling caused by heavy/floating mouse, desync, heavy car bug, input lag, etc.
viewtopic.php?t=14611
- naporitan
I fixed the problem, but English is not my native language and I'm too lazy to explain even in my own language.
- naporitan
Here are a few recommendations: use Windows 10 Pro in your native language, meaning download an image that's already prepared for your region.
Use the default BIOS settings, enable EXPO/XMP, and disable the processor's iGPU.
Connect your mouse and keyboard to the same USB controller. On Ryzen systems, the mouse shouldn't be connected to the USB port connected to the processor. For example, I have a B650 Aorus Elite AX V2 motherboard, and there's a USB hub on the rear panel with a Realtek controller.
Enable GPU Scaling + checkbox, disable G-Sync, DyAc, BFI, etc.
Use the default Nvidia 3D settings.
Avoid tweaks.
Do not change the windows power plan/timers/regedit..
Always install motherboard drivers from the manufacturer's official website asus/msi/asrock etc...
There are still many nuances that I am too lazy to remember and write about.
Avoid tweaks.
Hyote
I'll share some advice for the 100% perfect conditions for gaming:naporitan wrote: ↑02 Jan 2026, 21:42Here are a few recommendations: use Windows 10 Pro in your native language, meaning download an image that's already prepared for your region.
Avoid tweaks.
have water in your body
always use one or two hands to move your mouse
avoid playing video games in a housefire
make sure your computer is real
ask manufacturers if you can touch the purchased devices directly
always follow the rules created by video game developers and ask your fellow players if they consent to play with you
ablemor
Why is it good if I disable the iGPU?
ablemor
naporotan dont repeat yourself, say something new these are basic things, please.
valhalla
yeah .... its not settings like i said.... tested these weeks every time between 22:00 23:00.../ till +- 6:00 7:00 ... its gone world of differents..
like what i say its not internet related or anything, because i noticed it even offline on aim_bot map.
next month i order a battery and let you guys now.
astroasis
I've had the mysterious input lag (electricity issue from the supplier, it isnt your house/apartment) since 2018, think about how much time has been wasted not being able to play games properly, id suggest you all to cut your losses now and take up a different hobby (we arent allowed to game) or just get enough money and move if you dont have rich parents or whatever, the mental health decline isnt worth it trust me
