I solved floaty mouse and input lag for myself (I really did this time around)
Hyote
Re: I solved floaty mouse and input lag for myself (I really did this time around)
Post by Hyote » 26 Apr 2026, 15:08
Apexer15 wrote: ↑
26 Apr 2026, 13:15
aranamatthews2 wrote: ↑
26 Apr 2026, 02:28
after using this tweaked windows build for a couple weeks in combination with a few game/hardware specific tweaks, i can confidently say it makes every other windows-related tweak i've tried obsolete. a lot of shi is broken and it takes some fking about to troubleshoot issues but once it's setup then ur sweet. my inputs have never felt better, and the price it costs even in it's early/unfinished state is honestly still a fat bargain. i don't have benchmarks but i play gc3/ssl rl and semi-pro halo, and aside from the very obvious perceptual latency reduction and input feel, i am measurably better than before. if you're like me and want to spend your time actually playing games instead of tweaking them then this is one of the best one and done solutions :D
What do you exactly mean by "measurably better than before"? Like is it perfect hit reg? Mouse movement is working great or only a tiny improvement? Please elaborate
@Hyote, I'm not very expert with windows installation stuff but I have a handheld PC that I want to keep it's stock windows on it, it's a 25h2 windows 11 so I got some questions plz, ①what is the size of the data you're selling exactly and much disk size does it need? Since e my PC is only 512GB storage, ② are you selling a custom windows or the Frenzy tool as I can see its name in the link is an exe file that just needs to be installed on any Windows 11 system?
③ is apex legends safely playable after I install that Frenzy tool /custom windows?
④ If it's a custom windows 11, can it be installed side by side with my currently installed windows 11 25h2?
Ty in advance
The installed ISO is exactly 10 GB. I moved on to another project so I have a tool called sfera now which is around 30 MB. I think Apex should be playable, EasyAntiCheat has no problems with either Frenzy or sfera or any other AC. It can be installed alongside a stock one but I doubt it would work on a handheld.
