G-Sync game compatibility - Post your test results here
nimbulan
Re: G-Sync game compatibility - Post your test results here
Post by nimbulan » 22 Mar 2015, 10:54
MxOAgentJohnson wrote:Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
the games tested Tomb Raider, Batman Arkham Origins and Ethan Carter.
My mouse is a Razer Abyssus at 1000hz polling rate, infact if i turn the polling rate down it stutters even more.
If the fps is locked to 60 or 120, always the mouse is fine.
This is getting weird.
That's interesting, I don't remember anyone reporting similar issues with any of those games. What are your system specs?
MxOAgentJohnson
Post by MxOAgentJohnson » 22 Mar 2015, 13:12
CPU: i7 4790k Devils Canyon @ 4GHZ - GPU: MSi 970 4GB - RAM: 8GB Samsung Green - HARDRIVE: x1 840 SSD, x1 2TB WD, x1 250GB Maxtor - Motherboard - Asus - Cooler Akasa Venom
Alexious
Post by Alexious » 22 Mar 2015, 13:36
MxOAgentJohnson wrote:CPU: i7 4790k Devils Canyon @ 4GHZ - GPU: MSi 970 4GB - RAM: 8GB Samsung Green - HARDRIVE: x1 840 SSD, x1 2TB WD, x1 250GB Maxtor - Motherboard - Asus - Cooler Akasa Venom
What kind of GSYNC monitor do you have?
MxOAgentJohnson
Post by MxOAgentJohnson » 22 Mar 2015, 15:21
Wont make a difference but acer 27" 1920x1080
sharknice
Post by sharknice » 22 Mar 2015, 20:18
MxOAgentJohnson wrote: Right now i'm trying 3 games out, if the fps fluctuates on them the mouse stutters but if i use a gamepad it is silky smooth if the fps jumps about
It sounds like your mouse settings are bad. Are you using mouse smoothing, acceleration, or anything else like that? I know Razer has options to use non-native mouse DPI which could also be messing it up.
MxOAgentJohnson
Post by MxOAgentJohnson » 22 Mar 2015, 21:17
Nothing to do with mouse, happens on multiple mouses, multiple pcs and doesnt happen with gsync off in these games, its the games and gsync itself.
sharknice
Post by sharknice » 23 Mar 2015, 02:36
I've never had any of those problems in Tomb Raider. I don't have the other games. It sounds very similar to the effects of using poorly programed mouse smoothing or acceleration that is dependent on frame rate.
MxOAgentJohnson
Post by MxOAgentJohnson » 23 Mar 2015, 20:48
Its not every game that this happens, some games are amazing regardless of framerate, others just get an odd hitchy camera when the fps is in the 72-89 fps zone for some reason. Splinter Cell, Tomb Raider, A bit of Hitman Absoloution, Hard Reset.
However Sleeping Dogs, Resident Evil 6, F3AR are all fine regardless of the fps, so no idefa.
sharknice
Post by sharknice » 23 Mar 2015, 23:26
I also have splinter cell and have never had problems with that one either.
nimbulan
Post by nimbulan » 24 Mar 2015, 00:13
I know that Hard Reset's engine (also used in Shadow Warrior) is known to not run smoothly. Tomb Raider has been one of the smoothest running games I have ever played on my system both with my old GTX 760 and my new GTX 970.
