BenQ XL2720Z - XL2420Z V4 firmware download
Falkentyne
Re: BenQ XL2720Z - XL2420Z V4 firmware download
Why do you need V4?
You can update from V1 directly to V5. You don't need inbetween version.
Just flash V5.
Just flash V5.
rajdR
Hey, thanks for reply. I dont know if i can. I've read somewhere i have to flash from v2 to v3 to v4 etc. I have already v3. If i can update directly to v5 it would be nice.
Shaoqiang
sure - its possible
rajdR
Ok then, i will try it. Thanks alot
rajdR
Ok, i'm back with successfully updated v5 firmware with my own builded MSTAR upgrader
. Finally, i have no problems with losing of signal with DP port. Its amazing. Thanks alot guys.
Falkentyne
You're welcome.
Remember you can use a new AMA mode by turning on blur reduction first, then set or move the AMA setting to high afterwards (on XL2720Z this will remove all the inverse ghosting but you may have to lower contrast to reduce the extra normal ghosting that is added. On XL2420Z and 11Z, it only removes a small amount of the inverse ghosting).
This was added in V3 firmware for all of the monitors.
I don't know if it exists in XL2430T.
On XL2420Z and XL2411Z I don't know.
You can also get this AMA setting to work with blur reduction off, from a firmware bug with profile presets. (by doing the above first, then activate a gamer 1-2-3 preset with blur reduction off, but turning off blur reduction directly will not work).
I mentioned it here:
http://forums.blurbusters.com/viewtopic.php?f=13&t=2590
Spider-Waffle
My XL2720Z came from Amazon with V3 firmware, I'm wondering if there's any reason to flash to V5, is it worth the trouble?
Also any reason to use ToastyX pixel clock patcher to remove the limits, the VT 1350 tweak and strobe utility seem to be working fine with the DVI-D dual cable it came with.
Bloxicity
Does anyone have working download links for the XL2420Z - V4 or V5 firmware (or .bat)?
All links I saw so far are dead.
Falkentyne
I uploaded them here.
https://onedrive.live.com/redir?resid=3 ... lder%2crar
Note: no one has dumped any XL2430T version anywhere.
Bloxicity
Thank You! Now i can finally get to flashing.
