XL2720z V2 + BB Strobe Utility = Greatest Gaming Monitor!
Re: XL2720z V2 + BB Strobe Utility = Greatest Gaming Monitor
Post by Chief Blur Buster » 21 May 2014, 23:53
SUOrange55 wrote:Thanks. Loving the monitor.
Anything I can do to reduce some of the color saturation to make things more "bland/muted"?
Increase the gamma.
SUOrange55
Post by SUOrange55 » 22 May 2014, 08:30
Increase the gamma.
I'm using the TFT ICC profile and their recommended settings:
Standard mode
Gamma 3
Brightness locked at 100 with Blur Reduction enabled
Contrast 50
RGB 100/100/92
Everything else in the OSD settings is left at default.
Switching between the 5 gamma modes doesn't seem to make much of a difference. It's pretty tough to track targets on my screen in darker areas on maps, even with persistence at 100% (with things becoming too washed out at that point).
I wonder if there's a better a better color profile for gaming than TFT's, or if there's anything I can further tweak in nvidia control panel? I want the colors to be as bland and neutral as possible. I'm coming from using a XL2410T FPS default preset:
Brightness 100
Contrast 63
Gamma 1.8
The motion clarity/lack of any noticeable input delay on this thing is amazing so I would love to get the colors right for me. Thanks again for your help
kaemon
Post by kaemon » 03 Jun 2014, 10:22
Hi, i have recently bought the XL2720z. I am runing persistance on 2ms and crosswalk as far as i can to the left in the utility, which still isn't enough. I have applied the 1350 tweak in cru and i am still not satisfied. I still have crosswalk in the ufo test.
I am wondering what values you have on these settings:
AMA
Instant Mode
Sharpness
Q83Ia7ta
Post by Q83Ia7ta » 03 Jun 2014, 11:57
kaemon wrote:Hi, i have recently bought the XL2720z. I am runing persistance on 2ms and crosswalk as far as i can to the left in the utility, which still isn't enough. I have applied the 1350 tweak in cru and i am still not satisfied. I still have crosswalk in the ufo test.
AMA
Instant Mode
Sharpness
Utility is for BenQ Blur Reduction Mode. Are AMA and Instant Mode options changeable if BenQ Blur Reduction Mode is ON?
Instant Mode must be OFF only if you want some additional input lag so better keep it always ON.
SUOrange55
Post by SUOrange55 » 03 Jun 2014, 12:01
I actually have the same issue -- VT1350 @ 120hz and cross all the way to the left in the Utility; still get cross on UFO tests.
RustinSpencerCohle
Post by RustinSpencerCohle » 03 Jun 2014, 16:54
you dont get totally rid of cross talk or ghosting but it is only in at the upper and the lower edge of the screen with 1350 and all to the left. without 1350 the sweet spot for me was about 1/4 or 1/3 of the way from the left to the right.
Post by Chief Blur Buster » 03 Jun 2014, 18:01
It's important to note that LightBoost and ULMB also has crosstalk too, to varying extents, depending on the model of the monitor. In many areas, it is even worse.
-- Try VT1500 (after the ToastyX Pixel Patcher)
-- Try lowering contrast. This reduces crosstalk
-- Try 100Hz instead of 120Hz
Also, remember that the strobe crosstalk isn't as noticeable in real-world gaming as it does in the TestUFO.
kaemon
Post by kaemon » 04 Jun 2014, 14:50
EDIT: I compared vt1350 and 1500 and it doesn´t seem to make a difference. Right now there´s two weak transparent afterimages for each ufo. Top and bot of the screen has some crosswalk. I just wish that i could move the crosstalk slider more to the left in the utility.
Will i damage my monitor over time or reduce it´s lifetime by runing vt at 1500?
I am unable to add 144hz in CRU, what values do i need to use?
EDIT2: i am now running vt 1502 and i am noticing a huge difference in crosswalk at the top and bottom of my screen. Is it safe to run vt 1502 on lower refresh-rates?
Post by Chief Blur Buster » 09 Jun 2014, 22:02
kaemon wrote:EDIT2: i am now running vt 1502 and i am noticing a huge difference in crosswalk at the top and bottom of my screen. Is it safe to run vt 1502 on lower refresh-rates?
Yes, you can do VT1502 on many of the lower refresh rates. It actually makes a big difference for those, too.
patrickisfrench
Post by patrickisfrench » 11 Jun 2014, 01:55
Is there any benefit to me using this dual link dvi cable:
http://www.monoprice.com/Product?c_id=1 ... 1&format=2
over the one that comes with the XL2720Z? enhanced colors? better refresh accuracy? better response times? or am I absolutely fine with stock cable, no difference at all?
