Page 5 of 55
Posted: 21 Jul 2019, 09:24
by hleV
akhyg wrote:
i dont see any "Yes" after Test, maybe that notification goes to the primary monitor (xl2411z) and on extend i cant see it ?
how i do this (except drag from primary after where they opened)-> *Launch SoftMCCS and Nvidia onto 2nd monitor
Move NVIDIA CP to the 2nd monitor, and try to create a custom resolution <144Hz, and press Test. Then you will see where the "Yes" prompt appears without your XL2411Z going out of range.
urut wrote:
In my case csgo fullscreen works when i created cru resolution but with 1 pixel hiigher than its normal. I play csgo on 1280x1024 so i created in cru 1280x1025 (yes, 1025) and set it on desktop on 210hz, then launch csgo and its working, mat info showing 1280x1025 @ 210hz. Try it maybe.
I tried 1920x1081 and 1920x1079, nothing changed. Can't be bothered to do more testing, just hoping for the app to come out in the near future. It's pretty cool that CSGO accepts -freq/-refresh launch parameter, that way you can keep the desktop at 144Hz and only use the overclock while in CSGO.
Posted: 21 Jul 2019, 12:12
by akhyg
I've created 200hz resolution after all. Still grey and i can't activate anything. I've tried to reinstall, same issue.
https://imgur.com/D2vcty5
Posted: 21 Jul 2019, 13:24
by hleV
Okay then perhaps it's due to a too old monitor firmware.
Posted: 21 Jul 2019, 13:25
by urut
hleV wrote:Okay then perhaps it's due to a too old monitor firmware.
try maybe lower resolution, in my case 1920x1079 not workin too but 1280x1025 works, dunno why.
Try it maybe just for test, timings:
Horizontal : 24,32,80,136,1416 +
Vertiical : 3,5,61,69,1094 +
Refreshrate 210hz, Pixel clock 325.32
Created by CRU
Posted: 22 Jul 2019, 07:35
by akhyg
is working 200hz via dvi ,i didnt tried higher.
we need an app to do this automatic and no more out of range .
now what games can i play ? bordless or how i should do it ?
Posted: 22 Jul 2019, 21:48
by p1um4
hello!
on xl2411z via dvi:
working at 165hz and 180hz
200hz = pixels appear in desktop (non stable)
i use nvidia control panel with auto sync
please give correct value for 1920x1080 (165, 180, 200hz) or it safe to use auto sync?
Front porch: ?/?
Sync width: ?/?
Total Pixels: ?/?
Posted: 23 Jul 2019, 02:28
by hleV
I used the values provided by Chief in the 1st post, and my XL2411Z DVI works with 210Hz, 200Hz, 165Hz, etc.
Posted: 23 Jul 2019, 18:10
by hleV
I coded a little app for personal use (fullscreen CSGO at overclocked refresh rate). You can see the code and download the binary here:
https://github.com/hleVqq/AntiOutOfRange
Upon launch, it automatically detects your current OSD language (0xCC) and Color profile (0xDC) monitor settings, and re-applies those settings after X amount of seconds:
Posted: 23 Jul 2019, 18:24
by urut
hleV wrote:I coded a little app for personal use (fullscreen CSGO at overclocked refresh rate). You can see the code and download the binary here:
so other profiles will fork? for example FPS1 from xl2411z ? i will test it
#EDIT
Ye it works, thanks you so much
Posted: 24 Jul 2019, 17:51
by hleV
Made a different version called "OOR Fixer":
https://github.com/hleVqq/AntiOutOfRange/tree/OorFixer
It will stay in the background - didn't implement any tray icons so if you want to turn it off, do it via Task Manager. If you want it to be auto-launched with Windows, move
OorFixer.exe to
%ProgramData%\Microsoft\Windows\Start Menu\Programs\StartUp.
It auto-detects monitor event where refresh rate changes or it goes fullscreen (
WM_DISPLAYCHANGE event) and if refresh rate is >144Hz, re-applies OSD Language (0xCC) and Display Mode (0xDC) settings that were detected upon launching OOR Fixer. I adjusted the timings to the following: 2500ms after display change event, set OSD Language ("Out of Range" notification fix), after another 250ms apply Display Mode (black screen fix). This works ideally on my XL2411Z DVI, but on other monitors the timing may not match.
Sorry for the lack of features, I'm not a real programmer, just wanted this done for personal use.
