The predator is the only IPS240hz monitor that i've never tested. I will definitely test the acer predator(they ALL have the same exact panel, same with the nitro, except i heard that the predator has different OD tuning despite only having 3 overdrives. My prediction.. .Extreme is utterly useless with massive overshoot, "normal" overdrive has 0% overshoot but it wont' be as quick as the MSI. Then again, variable overdrive adds another different equation, if variable OD can improve the response time on the acer predator's "normal" overdrive setting, it can technically be as quick as the MSI or Alienware when it comes to g2g pixel response times.jiexiong2008 wrote: ↑14 May 2020, 21:31Hey guys. I am considering this vs other 240Hz ips alternatives. I only play league of legends (moba) competitively.
What is the response time and input lag for this monitor? I am currently using HP omen X 25f and it has ~2 to 3 ms from rting.com testing. Will there be huge difference if I transfer to new 240Hz ips monitors including this acer one?
i will be testing the acer predator xb273 x(the panel is the exact SAME the xb253q gx and the acer nitro xv273 x) and the TN acer predator XN253q version too(except the TN uses TN technology and not IPS technology)
My new digital oscilloscope and extra sensitive Photodiode just arrived. I'm just waiting for the predator to get delivered to me this sunday(LITERALLY nobody owns this monitor, it's the only 240hz IPS g-sync FYI but has VRR HDMI as a g-sync monitor which is a first). I will do a 100% FULL comparison(except the color accuracy) but when it comes to input lag and g2g response times, i am able to measure easily. between the 240hz IPS predator vs the 240 hz IPS MSI with real data.
That will wrap up the 240hz IPS testing for me. The 240hz IPS acer predator will be my final review up until: 360hz TN, Lenovo Legion, and the First ever 240hz 1440p IPS monitor Eve Spectrum.
