Reducing Input Delay with Nvidia Inspector
BTRY B 529th FA BN
Re: Reducing Input Delay with Nvidia Inspector
Post by BTRY B 529th FA BN » 06 Jan 2021, 17:56
Musashi
Post by Musashi » 31 Jan 2021, 23:41
Could you update the profiles it seems to be conflicting with driver 461 and just reverting the changes to default... :?
Amaterasu-dA-KinG
Post by Amaterasu-dA-KinG » 03 Mar 2021, 08:35
Do you have an updated version of the low latency riot v2? Because it's not working on the newest NVIDEA version. Which version should I use?
CreakFFM
Post by CreakFFM » 25 Jun 2021, 13:00
Thank you all for this amazing settings. Greetings to my friend melody.
I don't have this two settings. ***I FOUND IT***
Other
Frame Rate Monitor - 0x4A5A3219 PS_FRAMERATE_LIMITER_GPS_CTRL_OPTIMAL_SETTING
Frame Rate Monitor Control - 0x00000010
roro13200
Post by roro13200 » 20 Oct 2021, 16:46
Hello
I'm trying to import your profile, but I got the following message
failed to import base profile drs setsetting failed: nvapi setting not found
Calzzy
Post by Calzzy » 24 Jan 2022, 12:56
The Riot Low_Latency_High_Performance v2.nip and Riot Minimalist.nip say error when i try to import i have the latest version of profile inspector can you please send me screen shots of RLLHPv2 so i can do it manualy
sherifmagdy32
Post by sherifmagdy32 » 20 May 2022, 21:31
Calzzy wrote:
24 Jan 2022, 12:56
Nvidia removed some of the settings that we can change even using Nvidia inspector that is why you getting an error
what you need to try is go back to the default profile then try to apply the riot profile and see if there is any type of change if there is
it means it is applied but only gave an error because some settings don't exist anymore now you can export the settings into a new file so later you can just import without errors.
3xil3
Post by 3xil3 » 22 May 2022, 15:11
even with error mouse feels even more snappier than prior to using riot profile.
edit
also once added missing reg entry DisableWriteCombining 1 rebooted played doom eternal and mouse felt off remove and snappy again
sherifmagdy32
Post by sherifmagdy32 » 23 May 2022, 21:40
3xil3 wrote:
22 May 2022, 15:11
edit
This probably means all settings were applied except the once it didn't find that's why it gave the error that is a good thing
so the important settings that still exist are getting applied anyway.
I remember I saw in some forum that the disabled writing combing tweak is only for GTX cards or something like that also like any tweak you might experience different results from everyone else so test and decide for yourself if it is working or not.
Eonds
Post by Eonds » 27 May 2022, 13:38
sherifmagdy32 wrote:
23 May 2022, 21:40
3xil3 wrote:
22 May 2022, 15:11
edit
Any GPU that can use drivers below 457.30 can use the "dword". It's a matter of driver implementation. I can confirm this because I have the source code. All drivers after 457.30 to my immediate knowledge is deprecated along with many other settings.
