Page 5 of 5
Re: Bad input lag/desync issue: Testing with AW2521H 360Hz monitor w/ Nvidia latency module
Posted: 21 Feb 2023, 18:33
by Shade7
I'm surprised there weren't more responses/updates to this discussion.
The post suggesting to disable any kind of NIC processing might be on to something there. Playing Valorant after disabling some of the options mentioned definitely has improved the smoothness of my gameplay, and has helped minimize strange/unpredictable behavior I used to notice during gameplay. I wonder if there are other options in my NIC advanced settings that can be further tweaked to avoid running into this issue.
Posted: 22 Feb 2023, 03:27
by Kyouki
Shade7 wrote: ↑
21 Feb 2023, 18:33
Could you clarify this post? "disable any kind of NIC processing might be on to something there." - couldn't find the reference.
Posted: 26 Feb 2023, 20:59
by Shade7
Kyouki wrote: ↑
22 Feb 2023, 03:27
Shade7 wrote: ↑
21 Feb 2023, 18:33
Haha, took me a second to find it again as well. It's the post by Spoidah (on 06 Mar 2021, 06:45) on Page 4 of the thread.
Posted: 30 May 2023, 01:05
by AudAmerica
great idea! Looking forward to more updates
Posted: 02 Jan 2024, 10:37
by Kvoyn0v
I think this is what we are all dealing with
Posted: 02 Jan 2024, 10:57
by RealNC
spoidah wrote: ↑
21 Feb 2021, 16:00
I've completely overhauled the first post. I am now quite sure about what is causing our issues, it is a very sophisticated problem with power that causes EMI and various other issues we've all assumed is the cause of our problems. The long and short of it is we are dealing with harmonics, but not the 'normal' kind.
Moving the thread to the appropriate section then.
