Re: Electricity input lag fix !
Posted: 20 Apr 2021, 10:08
guys how many of you have near your house high power lines or trafo stations?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
Chief Blur Buster wrote: ↑19 Apr 2021, 22:42
I am flattered you would ask: I am more of the guru of monitor motherboards (the stuff inside your monitor) rather than PC motherboards.
However, there are quite a few motherboard hackers in these forums, though they may more quickly notice a subject title "Need Firmware Hack for [MOTHERBOARD MODEL] to enable spread spectrum to resist EMI better" or such. If you wish, I could split your post into its new fresh thread, to get the thread-title highlight. On the other hand, reusing a popular thread (as long as ontopic) can stay visible longer. Pros/cons... Perhaps wait a week or two before PM-ing me to ask for a thread split. (Note: PM'ing admins/mods is only for forum support)
You could link to this post from some certain areas of Discord (HalfwayDead's Rocket Science as an example) as well as high-skill friends of Blur Busters such as Guru3D who's collaborated with Blur Busters on certain things (such as improving RTSS), though knowledge about genuine EMI issues varies between different forums. I welcome further collaboration in this area. Your permalink is as follows:However, I welcome others to take upon your offer [be safe about it though, check cred/reputation/etc]Code: Select all
https://forums.blurbusters.com/viewtopic.php?f=10&t=8532&p=66436#p66430
P.S. To make it easier for others to read the text in your imges, I modified the UBB coding in your post to make your images clickable/zoomable. with technique:Code: Select all
[url=address][img]address[/img][/url]
pox02 wrote: ↑19 Apr 2021, 23:59@alexander1986
try this
https://easyupload.io/phvfou
run export.bat
If all things correct, it should export to a txt file with all BIOS settings. Just change the * to what you want the new value to be.
Supports everything hidden (and visible)
Import.bat flashes the txt again
Reboot, and check if it worked
blackmagic wrote: ↑20 Apr 2021, 04:16@alexander1986
you can open the bios with AMIBCP patched one that is for z390...
https://disk.yandex.com/d/vJAIK82mvATlZg
just rename the bios then to mybios.rom and you rdy to go and edit what is possible to edit.
but here im stuck and dont go further...
i better wait for @yonaxsangi before doing something by myself...
i just hope it is possible to edit our bioses. msi is not rly nice to us and hides so many stuff...
already saw msi forums where users complain about that all...
and yes hpet seems to be already enabled by default on our boards, bios.
hardhit wrote: ↑20 Apr 2021, 05:07Apologies if mentioning another website is against the rules, however as this could be beneficial for obtaining any additional information about the bios settings I would suggest asking in win-raid community, to be exact "request a bios modding" section. Uppon request, they have modded my msi b450m bazooka max wifi bios twice, first time to expose HPET switch and second to update bios modules such as realtek and others etc.alexander1986 wrote: ↑19 Apr 2021, 20:11guys, * warning * for LONG post with a lot of pictures and info coming, but I think is very relevant.. anyway.
kind regards , /Alex
They modify your bios so it easy to flash as a regular bios
Provide your motherboard name, the link to bios file, bios file name and what you want to be modified. From my experience I got the modifed file as soon as 2hours from my request
https://www.win-raid.com/f54-BIOS-Modding-Requests.html
deama wrote: ↑20 Apr 2021, 19:27I was thinking maybe you can add EMI shielding by yourself? Like what if you cover the mobo with an anti-electric conductive material, then cover that with copper tape (for shielding)? I don't foresee any heat problems as I don't think anything needs much cooling on the mobo, even then, if you used a heat conductive, but not electricity conductie material, that should fix it.
You could add that on both sides, then mobo would be protected from all sides. Obviously you'd have to leave a few blocks open like NVMe, RAM slots, pcie slots, cpu slot, but should be interesting to try though.
Another idea would be to add some shielding to the back of the GPU, but I think they kinda have one anyway these days (my one has a metal plate at the back).
Best would be to add some sort of shielding to the PSU though, especially if you don't have a good one, cause that one seems to produce the most EMI.
Chief Blur Buster wrote: Moderator Note: Edited images to be clickableCode: Select all
[url=https://i.imgur.com/d3hp3QA.png][img]https://i.imgur.com/d3hp3QA.png[/img][/url]
ahh I see well I wish you good luck sir, am still trying to figure out best way to just make this single change to 6% from 1.5% default value and then reflash..blackmagic wrote: ↑21 Apr 2021, 09:14ye i do many pretty stupid things here...
but i have good hope to make this board work again...
i already order a eeprom flash bios usb with clip only 12 euros and watched some youtube tutorials where guys manage to flash/reflash on that way there bioses and make it work for the new cpu where boards dont supported before and bios update was need...
gonna then report tomorrow if i manage to recover the black screen on that way...
the 255 value is for intel ICC spread%...
@yonaxsangi said that in one of his comments on page 1...
blackmagic wrote: ↑21 Apr 2021, 16:07
i ordered a new mobo aswell here but a cheap one...dont want waste to much money on that bullshit issue i have...
but that mobo should have 1x spread spectrum option like my old mobo had too.
so in less than 2 days i gonna know for sure if that makes some differences or not and if this spread spectrum can get corrupted after a time of usage...that what is interesting for me...
because my problems started already on my old mobo which had this spread spectrum...
but i gonna try that bios tweak on z390a-pro too if the recover works with eeprom flash bios usb...
you can wait 2 days ? let me go first and mess up things here...
and then i can tell more to you and you dont need mess up with ur motherboard...![]()
well its good at least that you got some improvement, only question is if it will be consistent day in and day out I guess, and probably situation can be different for different users depending on the nature of their EMI/RFI problem I guess...BTRY B 529th FA BN wrote: ↑21 Apr 2021, 16:25For me on my X570 Xtreme setting the bus clock to Auto while disabling Spread Spectrum made a positive improvement. For the longest time I thought by setting my Bus clock to 100 effectively did the disabling but it seems setting the bus clock to Auto is best with Spread Spectrum disabled.
BTRY B 529th FA BN wrote: ↑21 Apr 2021, 21:35That sucks man. I hope you get it to work. I feel if I didn't happen to check out this thread and dig deeper into my own Spread Spectrum settings with both my boards, I would of jumped on a Rocket Lake system. I was kinda relating the USB issues with the inconsistency in online gaming while all the long thinking I had properly configured Spread Spectrum to disabled. To me this experience has literally been 'night and day.'alexander1986 wrote: ↑21 Apr 2021, 20:11well its good at least that you got some improvement, only question is if it will be consistent day in and day out I guess, and probably situation can be different for different users depending on the nature of their EMI/RFI problem I guess...BTRY B 529th FA BN wrote: ↑21 Apr 2021, 16:25For me on my X570 Xtreme setting the bus clock to Auto while disabling Spread Spectrum made a positive improvement. For the longest time I thought by setting my Bus clock to 100 effectively did the disabling but it seems setting the bus clock to Auto is best with Spread Spectrum disabled.
cant even change the setting on my mobo without doing this bios hacking lol, ah well ! it is what it is![]()
It feels as consistent as having the bus clock set to 100.00Mhz wasn't consistent. Yes, it's been better the past 24hrs and improvement with online gaming was immediately noticeable.
I'm hoping the effect will improve my IF clock max stability. I've been limited to 1866/3733 so I'm hoping I'll be able to do 1900/3800 without any WHEA errors in stability tests. Will know pretty soon.
EDIT: Well it's a good sign passing OCCT default stress test 1hr without any WHEA errors. Still more testing to do, but before changing my Spread Spectrum configuration around I would have had a WHEA error.![]()
