Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
ApexLeg
Post
by ApexLeg » 01 Jun 2024, 14:37
Sandy wrote: ↑01 Jun 2024, 13:51
ApexLeg wrote: ↑31 May 2024, 16:46
Sandy wrote: ↑31 May 2024, 14:43
bwainzz wrote: ↑28 May 2024, 18:02
Explain pls
Now it has been confirmed that there is a USB overlap bug in Windows system. Follow this post to solve the problem successfully. It is permanently solved~
What's the fix and how long has it been 'solved' for you?
I can't send pictures. You just need to follow the contents of this post carefully. Uninstall all USB devices, then install the mouse and keyboard, and disable all USB branches except the mouse and keyboard. Only keep the basic functions of the mouse and keyboard, and never plug any USB devices into other USB ports.
Thanks - I'll give it a go.
You say it's been confirmed, is that your own confirmation or is there officially one?
cursed-gamer
Post
by cursed-gamer » 01 Jun 2024, 18:06
Why is it so sensational while Windows format should do the trick?
Sandy
Post
by Sandy » 01 Jun 2024, 21:34
ApexLeg wrote: ↑01 Jun 2024, 14:37
There is no confirmation from Microsoft. I remember that some software developers mentioned the Windows queue sequence BUG in the early years, but I didn't pay attention to it. I thought it was his placebo. Now I see this post and I know that the problem that has been bothering me is caused by this BUG. If you have the ability, you can submit this BUG to Microsoft. I don't know how to operate
Sandy
Post
by Sandy » 01 Jun 2024, 21:36
cursed-gamer wrote: ↑01 Jun 2024, 18:06
This depends on the insertion sequence of your USB devices. This is a probability problem and the registry cannot have any USB device entries left.
cursed-gamer
Post
by cursed-gamer » 02 Jun 2024, 04:33
Sandy wrote: ↑01 Jun 2024, 21:36
What is insertion sequence of USB devices? Never heard of such a thing.
Sandy
Post
by Sandy » 04 Jun 2024, 18:45
cursed-gamer wrote: ↑02 Jun 2024, 04:33
My lag is back.... The USB port queue sequence is a long-standing bug. You can only gamble every time you boot up. The HID item of the mouse in the device manager has a certain chance to change every time you boot up. If it changes, then everything you set up before will become invalid. The input lag is back. I am trying to find the boot with 0 input lag, make a Windows backup, and then restore the system every day when I come back to play games. This is the solution I can think of.
F1zus
Post
by F1zus » 05 Jun 2024, 17:10
Sandy wrote: ↑04 Jun 2024, 18:45
Because obviously the problem is not with the HID devices or the order in which they are connected.
The problem is with the USB drivers, we don't know what exactly happens to them after uninstalling them from the device manager.
Perhaps the priority of the drivers/usb is changing, perhaps the driver threads are switching to another kernel, perhaps a different USB performance state is enabled, perhaps there are changes in the Windows timer.
We don't know for sure.
We need a WPA tool and use it to track changes.
F1zus
Post
by F1zus » 05 Jun 2024, 17:13
I tried to figure out why the mouse became much more responsive after changing the polling rate or dpi to the same value, but I couldn't.
The only thing I understand is that this problem occurs on all versions of Windows and on Ubuntu (linux). I was unable to reproduce the problem on android 12 and snap 870.
Post
by Slender » 05 Jun 2024, 19:35
F1zus wrote: ↑05 Jun 2024, 17:13
Sems like hardware issue. Not OS.
you can check changes in regedit (after/before change) but im not sure you find some.
I have the same, when i hard-reset my mice (connect-disconnect sound), im feel better responce and speed.
Do you try disable / enable usb options (maybe some hidden) in bios?
Show me your usbtreeviewer.
Hyote
Post
by Hyote » 05 Jun 2024, 20:00
If people claim their mouse to be anywhere near responsive while they have hidden devices I can finally call this complete bs. The top posts are about s1mple's desync, some made up Management Engine bug and switching dpi. Whoever has 5 more iq points than the general population please at least put some effort into inproving and solving these issues. I made my own version of W10 22H2 and it brings improvement. Same goes for the settings in my posts. I don't get why there are 1 or 2 useful posts every few months, then the rest is absolute madness.
