Page 41 of 73
Posted: 15 Jul 2021, 05:06
by Discorz
Blehhh wrote: ↑
15 Jul 2021, 04:58
Its OD level inbetween 60 and 80 for VG259QM.
On VG279QM is inbetween 80-100, more like OD85/90.
Posted: 15 Jul 2021, 05:08
by Blehhh
Discorz wrote: ↑
15 Jul 2021, 05:06
Blehhh wrote: ↑
15 Jul 2021, 04:58
yeah using VG259QM , in rtings website it says OD 60 its better than OD 120 and OD 80 not sure which is the best, i trust this forum, which is the most optimal settings?
once you on 120OD is your monitor able to change back to default OD 60 or OD 80?
Posted: 15 Jul 2021, 06:07
by axaro1
Blehhh wrote: ↑
15 Jul 2021, 05:08
Don't listen to RTings.
OD120 is arguably the best overdrive at 280hz, especially if you use ShadowBoost since it looks like only the darkest transition seem to suffer from overshoot and equalizing dark levels can effectively remove overshoot even further.
OD80 is a good alternative, IMO there is a little bit too much overshoot but it's definitely usable.
Blehhh wrote: ↑
15 Jul 2021, 05:08
Yes
Posted: 15 Jul 2021, 06:12
by Blehhh
axaro1 wrote: ↑
15 Jul 2021, 06:07
Blehhh wrote: ↑
15 Jul 2021, 05:08
Blehhh wrote: ↑
15 Jul 2021, 05:08
Yes
Thanks , to unlock OD 120 just follow ur first post?
so theres zero to no harm in unlocking OD120 right?
thanks for helping me out :)
Posted: 15 Jul 2021, 07:44
by axaro1
Blehhh wrote: ↑
15 Jul 2021, 06:12
Yes, follow this guide. There is no harm in using OD120.
Posted: 16 Jul 2021, 07:24
by ekajjj
Can anyone tell me a bit more regarding VividPixel? I really like this monitor and have tried using 25-50 on the setting, but having seen mosts from a few years back regarding VividPixel on older ASUS models it was suggested it may increase the response time. If anyone is knowledgeable on this I'd greatly appreciate some information.
Thanks
Posted: 22 Jul 2021, 10:56
by zonk
hey I just followed the steps, nice Thread! been a while is there any updates?
Posted: 22 Jul 2021, 16:25
by ryshan53
Max_hz wrote: ↑
17 Aug 2020, 09:26
Thanks, nice find! I wil try it in game and looks how this "OD 120" feels, at ufotest for me it looks like between OD 60 and OD 80.
Must be a bug in the FW nevertheless it could be very useful, will report later.
Good idea to make a exclusive thread for the VG259QM, btw I have FW MCM104 also.
I cant change mine to 120 od, whenever i press od strong weak off, and press exit or leave, there is no 120 od option and it always resets to od strong on. What do I do?
Posted: 23 Jul 2021, 17:33
by SkooR
Hello guys
Im thinking of going to xl2546k instead of my vg259, is there any big difference i mostly playin warzone
Also what is best od for 180hz should I go with 120od ?
Posted: 23 Jul 2021, 20:14
by ryshan53
axaro1 wrote: ↑
15 Jul 2021, 07:44
Blehhh wrote: ↑
15 Jul 2021, 06:12
whenever i turn off od strong weak off and press exit, it just keeps going back to on. How do i save it or actually turn it off?
