maybe swap ports and swap which display is primary and try again. Maybe it's a delay from cloning the display. if you swap that will tell you.Chilicrunch wrote: ↑23 Aug 2021, 19:09It's from Lagom's LCD test page. I cloned the output of the two displays and took a photo. It's not gonna be very accurate, and it can only compare the lag between the monitors being tested, but it's enough to see that there's a decent amount of lag in 60hz mode for the XG2431. It's definitely less than the other monitors I have at 60hz though and I'm not concerned about it at all for anything other than fighting games.
brandon9271
Re: ViewSonic Now Shipping XG2431 as of NOW!!! [Blur Busters Approved XG2431 - 24" 240Hz IPS]
datspike
Sadly you can't compare lag like that as the display output cloning introduces a moderate amount of lag. You could swap primary monitor and test the opposite scenario, I bet you would see more lag in your old monitor.Chilicrunch wrote: ↑23 Aug 2021, 19:09It's from Lagom's LCD test page. I cloned the output of the two displays and took a photo. It's not gonna be very accurate, and it can only compare the lag between the monitors being tested, but it's enough to see that there's a decent amount of lag in 60hz mode for the XG2431. It's definitely less than the other monitors I have at 60hz though and I'm not concerned about it at all for anything other than fighting games.
XG2431 | MSI MAG251RX | Lacie 22b4 | Sony F520
Chilicrunch
Which would have higher lag? The primary or clone? Viewsonic was primary in my test, it also had less lag than the AOC at 240hz than the AOC.
masterblaster
Are there any in-depth reviews on this thing yet? I am waiting still..
brandon9271
i just got an email from sales that my order was delayed until Sept because of a firmware issue that made the monitor "underperform from the advertised specs." I guess they've fixed it and have to flash the new firmware before they can ship.. i dunno but I cancelled my order. I'm not in a huge hurry. I'm about to get my CRT out of storage. lol
- SixelAlexiS
Gotcha. Btw there isn't a single review of this monitor yet? I guess very few people care about this (I'm still seeking exact data on minimum nits for VRR mode).Chilicrunch wrote: ↑23 Aug 2021, 19:09It's from Lagom's LCD test page. I cloned the output of the two displays and took a photo. It's not gonna be very accurate, and it can only compare the lag between the monitors being tested, but it's enough to see that there's a decent amount of lag in 60hz mode for the XG2431. It's definitely less than the other monitors I have at 60hz though and I'm not concerned about it at all for anything other than fighting games.
AM_acc1q
They are taking their sweet time to ship the monitors...SixelAlexiS wrote: ↑24 Aug 2021, 17:04Gotcha. Btw there isn't a single review of this monitor yet? I guess very few people care about this (I'm still seeking exact data on minimum nits for VRR mode).Chilicrunch wrote: ↑23 Aug 2021, 19:09It's from Lagom's LCD test page. I cloned the output of the two displays and took a photo. It's not gonna be very accurate, and it can only compare the lag between the monitors being tested, but it's enough to see that there's a decent amount of lag in 60hz mode for the XG2431. It's definitely less than the other monitors I have at 60hz though and I'm not concerned about it at all for anything other than fighting games.
Chilicrunch
I swapped the test settings for the two monitors, made the AOC the primary and this was the result:datspike wrote: ↑24 Aug 2021, 05:09Sadly you can't compare lag like that as the display output cloning introduces a moderate amount of lag. You could swap primary monitor and test the opposite scenario, I bet you would see more lag in your old monitor.Chilicrunch wrote: ↑23 Aug 2021, 19:09It's from Lagom's LCD test page. I cloned the output of the two displays and took a photo. It's not gonna be very accurate, and it can only compare the lag between the monitors being tested, but it's enough to see that there's a decent amount of lag in 60hz mode for the XG2431. It's definitely less than the other monitors I have at 60hz though and I'm not concerned about it at all for anything other than fighting games.
Results look the same. I imagine the lag is lower than other 240hz monitors at 60hz, but it's still too much lag for competitive, at least the way I have it set up. Someone else said that there's a firmware update that's coming because the monitor is not performing at the specs or something, so maybe that'll do someone about it?
Just gonna have to wait on RTings I guess to do a proper lag test.
Zace
I wonder if AOC 24G2ZU use the same panel as xg2431.
michaelcycle00
