Page 43 of 55
Posted: 03 Apr 2021, 21:51
by benqoced86
Overclocking to 200hz was forcing the colours from 8bit to 6bit. I got more hz and also fps but...Don't waste your time!!!It's bad! ;)
8 vs 10
https://www.youtube.com/watch?v=NF-NamB2CUE
Posted: 06 Apr 2021, 03:53
by rafraf
Hello guys cant oc xl2411p
So first i try softmmcs with 2 screen and After with my phone when i click to occ and display app nothing happen seems like the prog doesn’t work.
After i try antioutofrange i tape 5 second for exemple and nothing happen stay in out of range.
After i try oorb v1.4 i run the programme change résolution and my screen goes out of range so i turn off my monitor and turn on after a alt+home then my screen shows half with benq logo in the middle and i must return to 144hz to fixe that, ».
I notice i have latest driver nvidia and my gpu is gtx780. Also my service page in attachment
Please try to help
Ty a lot
Posted: 11 Apr 2021, 14:13
by benqoced86
Added the firmware version in my previous post.
(or check my profile signature) ;)
Posted: 11 Apr 2021, 17:33
by rafraf
Ok maybe firmware problem cuz i have v009, can someone tell me how to return to the 002 ? S
Posted: 12 Apr 2021, 07:03
by rafraf
Can someone who has oc his xl2411p give his firmware version please ?
Posted: 17 Apr 2021, 04:11
by CtrL
Hi. I got the xl2411 screen and i get 165hz (probably can get more but there is where i started). In windows it works but when i open games it will not work and gives black screens and switches modes ect. I have followed the thread so i dont know what im missing here.
Posted: 17 Apr 2021, 07:31
by FastDuck
xl2420t v1 @120hz report:
S-switch metod, settings for 144hz
And settings for 200hz 1280x1024
Anything lower than 330mhz is fine.
With 200hz screen has bad color vibrance, colors looks washed out
Posted: 17 Apr 2021, 21:12
by rafraf
In my xl2411p anything lower than 330mhz get me no signal ( no out of range only no signal..)
Posted: 18 Apr 2021, 12:29
by FastDuck
rafraf wrote: ↑
17 Apr 2021, 21:12
I got no signal only when total pixels amount is low. Just use standart settings, try to increase frequency with 10hz step, you should see out of range message, use quide from 1st post for skip oor, increase monitor freq to artifacts and only than reduce total pixels amount with same 10 steps for stability
Posted: 21 Apr 2021, 14:49
by rafraf
I will wait for someone have xl2411p with firmware v9 to make a solution for this monitor.. ty guys
