datspike
Re: ViewSonic Now Shipping XG2431 as of NOW!!! [Blur Busters Approved XG2431 - 24" 240Hz IPS]
Post by datspike » 30 Aug 2021, 06:25
brandon9271 wrote: ↑
29 Aug 2021, 14:48
..unless I just happen to find a Sony GDM-FW900 at a flea market or something. 😆😁
Don't even bother finding a good FW900. They are made on the much older platform than 2070SB, F520 and other top of the line 4x3 crts and die way quicker because of a range of problems: tube, flyback, etc.
Not even mentioning that it tooks 20-30 minutes to warm up from a cold start and lower peak brightness. It's just a one big headache compared to a last gen 4x3 crts.
I've had 2 faulty ones and sincerely regret every meter I carryed those monsters LOL
XG2431 | MSI MAG251RX | Lacie 22b4 | Sony F520
Falkentyne
Post by Falkentyne » 30 Aug 2021, 13:05
How do you hook up these 2070SB / FW900 etc monitors to video cards that only have displayport?
Crazyness
Post by Crazyness » 30 Aug 2021, 13:14
Falkentyne wrote: ↑
30 Aug 2021, 13:05
maybe this.. https://www.amazon.com/Travel-Adapter-2 ... B00V6ADHEY
carlratcliffe
Post by carlratcliffe » 31 Aug 2021, 13:52
Hi just got the monitor and just wanted to ask something. I can't seem to access the BIOS. XG2431 will show [No Display] until windows login. I had to use another monitor to show BIOS. Is this something that I can fix?
Post by Chief Blur Buster » 31 Aug 2021, 14:00
carlratcliffe wrote: ↑
31 Aug 2021, 13:52
This can affect some motherboard with some displays -- try turn on/off FreeSync in the monitor's OSD. It will swap to a different set of EDIDs, one of which should show the BIOS.
If this fails, open a ticket with ViewSonic support (and share with me) so I can reach out to the XG2431 dev team. Thanks!
antiblur
Post by antiblur » 31 Aug 2021, 23:36
Hello, Chief. Сan u tell me, does this monitor support 240Hz strobbing? That is, will I have 240Hz with strobbing on, or will the frequency be lower? Sorry for my English.
monitors: TN ACER 1916 (75Hz)>TN ACER 1917 (75Hz)>XL2540K (240Hz)>IIYAMA MASTER VISION PRO 451 (CRT 160 Hz)>xl2546k>omen x 25>24g2zu>xv252qf
JDnoob
Post by JDnoob » 02 Sep 2021, 01:09
240hz strobing is supported but will have higher crosstalk.
I’m curious, what is the approximate brightness of this monitor at various strobe widths for 60hz? Is this posted anywhere?
What would the 60hz MPRT/strobe duration be at around 100 nits?
Post by Chief Blur Buster » 02 Sep 2021, 01:50
antiblur wrote: ↑
31 Aug 2021, 23:36
Yes. This monitor supports strobing from ~59 Hz through 240 Hz in essentially 0.001 Hz increments. You can strobe at any custom Hz you want!
There is a continuous continuum of strobe quality from lowest Hz to highest Hz.
JDnoob wrote: ↑
02 Sep 2021, 01:09
Still far lower than many other IPS monitors -- it's the best 240 Hz strobed IPS I've seen so far.
It is a continuous continuum of slightly improving strobe (by a fraction of a percent) crosstalk for every Hz you get below max Hz, until the crosstalk pretty much nearly zeros out (at ~120Hz QFT / large VT and below), it can be tuned to be barely visible at 144 Hz, but many don't mind 180Hz-240Hz strobe -- it depends on your personal threshold for seeing crosstalk especially at the top/bottom edges.
The center perfect crosstalk-free zone becomes taller and taller the more Hz you go below max Hz, which is due to a law of physics effect in the ratio of refreshtime:GtGtime ... Basically the refresh cycle time versus the pixel response time. ALL panels in humankind have worse crosstalk at max Hz. That's why NVIDIA locks ULMB below max Hz, but all Blur Busters Approved monitors always unlocks the strobe max Hz, so you choose to strobe lower Hz at lower crosstalk, or max Hz with more crosstalk.
JDnoob wrote: ↑
02 Sep 2021, 01:09
Supported pulse widths is 1% to 40% of a refresh cycle, so you can guesstimate it as percentages of max-brightness. However, there is a light amount (safe) of voltage boosting, so it will be slightly brighter than that minimum baseline -- probably exceeding approximately 200 nits at Light thanks to the voltage boosted strobes. (just like the XG270 does too). The sweet spot pulse width is usually either Normal or Extreme for most people, when using Large Vertical Totals at 60 Hz, which is capable of going darn near-zero-crosstalk during 25-30% pulse width.
PureXP default pulse width settings:
Light = 40% of refresh cycle
Normal = 30% of refresh cycle
Extreme = 20% of refresh cycle
Ultra = 10% of refresh cycle
Custom = Tunable 1% to 40% via ViewSonic Strobe Utility.
MPRTs will match pulse width, so pulse width 20 means MPRT(100%) will be 20/100ths of a refresh cycle, by the pure Blur Busters Law mathematics, excluding backlight decay effects (capacitors, fast backlight phosphor, etc) which adds approximately ~0.1ms. For most pulse widths, that is an insignificant error margin, and MPRT(100%) of a good strobe backlight pretty much exactly matches pulse width in milliseconds.
I will let reviewers test the actual brightness -- feel free to vote at RTINGS Suggest-a-Monitor for the XG2431 to be reviewed.
masterblaster
Post by masterblaster » 02 Sep 2021, 09:49
Wheres the official reviews of this monitor.... I havnt seen any.
carlratcliffe
Post by carlratcliffe » 05 Sep 2021, 09:57
31 Aug 2021, 14:00
31 Aug 2021, 13:52
I've sent a ticket with ViewSonic support and I have yet to receive a reply. So I've tried using an HDMI cable to plug my monitor, BIOS seems to post when using an HDMI. With a displayport cable, I can't get a BIOS post. is there a reason for this?
