girizgah
Post by girizgah » 22 Nov 2021, 08:04
My asus vg259qm just arrived today. Its firmware is MCM106. I am very happy with it. However, later I noticed a dead pixel (actually dead green subpixel) on the left side. I will try to return it to seller. Do you have any recommendation for dead pixel thing? In Turkey, many buyers experienced this issue. I fear that even if they return a new monitor, it may still have the issue.
uko
Post by uko » 22 Nov 2021, 12:46
does someone find the best settings for play warzone with around 120-160 fps?
balimka
Post by balimka » 25 Nov 2021, 15:25
Hey there, any settings recommendations for VG258QM? I couldn't find anything useful so far.
Quarksie
Post by Quarksie » 26 Nov 2021, 12:46
How do we upgrade to MCM106?
And to Axaro: whats makes you play more with this monitor vs XL2546K? isnt Dyac better than ELMB?
seabo
Post by seabo » 03 Dec 2021, 05:15
Hi guys, any recommendations for color/temperature settings besides racing mode? For example for FPS mode and RPG mode.
Truenozz
Post by Truenozz » 04 Dec 2021, 03:56
Hey guys! I'm trying to set the 10 bits color but in the CRU I can't see the option of Automatic - LCD reduced. Here is an screenshot:
tech
Post by tech » 14 Dec 2021, 15:40
Truenozz wrote: ↑
04 Dec 2021, 03:56
Hey guys! I'm trying to set the 10 bits color but in the CRU I can't see the option of Automatic - LCD reduced ...
From changelist:
"LCD reduced" has been eliminated because it was too arbitrary and only worked for certain resolutions. Try "Exact reduced" for an alternative.
tech
Post by tech » 14 Dec 2021, 16:02
I have a problem with lower resolutions not sticking. I want to run games in Fullscreen exclusive and the monitor to run at 900p@280Hz without GPU scaling.
When applying 1600x900 (900p) resolution via the Nvidia 497.09 control panel I'm seeing it reported to the monitor as 1080p and visually seeing 900p scaled up. Scaling is set to perform on 'Display' in NV control panel. I want it to report 900p@280Hz to the monitor without any GPU scaling.
To get 1600x900@280Hz to report to the monitor I need to use CRU and set a detailed resolution for it (exact reduced). But, after setting the desktop resolution to 1600x900@280Hz and loading up a game in Fullscreen (exclusive) mode with 1600x900 already set ingame, the monitor will revert to 1080p@240Hz upscaled from 900p. I've checked the Nvidia game profile to to use either 'Maximum refresh rate' or 'Application preferred', neither helped fix the issue. This has happens on multiple games. The only way around is to set the game to Windowed Fullscreen or Flip Fullscreen.
I want to run games in Fullscreen exclusive and the monitor to run at 900p@280Hz. Any ideas?
davidoo
Post by davidoo » 15 Dec 2021, 14:18
is it possible to upgrade the firmware on the monitor somehow? I have firmware ver. MCM102 on my vg279qm.
TakenZ
Post by TakenZ » 16 Dec 2021, 18:24
axaro1 wrote: ↑
20 Nov 2021, 04:36
ysenojftw wrote: ↑
20 Nov 2021, 00:34
In this scenario, elmb on, adaptive sync off at 280hz do I cap my fps at say 500 in csgo or do I cap below, I want the least amount of input lag while using elmb on 280hz.
If you can pull that much fps just go with the uncapped framerate.
Hey axaro1, it looks like you’ve changed up your monitor settings from the initial post. Looking through this thread, I see that you use the Rtings' ICM profile, 97-100-97 RGB, Racing Mode, Shadow Boost 3, OD 120, 280 HZ, ELMB ON with Adaptive Sync Off. Is that right?
This is for 200+ frames, I’m assuming, which is what I get in all my games except for Warzone. So in that game, should I do G-Sync On with OD 80? Lastly, what sharpening setting do you use? I find that anything above 0 makes it impossible for me to see enemies in Warzone. It gets really pixelated for me, but maybe I’m not used to it
