Fast enemies ferrari peaks and so (cs2 valorant input lag))
XEM
Re: Fast enemies ferrari peaks and so (cs2 valorant input lag))
Post by XEM » 12 Sep 2024, 17:05
cl_predict wrote: ↑
09 Sep 2024, 16:47
This gambling theory doesnt make sense for me … if u have no desync and u train hard and become good, your win % will follow, I was in this case. You can reach high elo even with this « desync/no time to react/input lag issue ». I fight this problem since 2019-2020 and I’m 3.5k elo on faceit, radiant on valorant. (But my valorant acc for exemple dropped from 1.6 to 1.1 kd, can’t hard carry some games like before etc… I had to change my gameplay for sure, that’s the sad part of this issue too). But I already reached radiant rank with new accounts really fast while playing with this issue (I had to train/grind 2 times more than I usually do tho). If someone tells you that you can reach REALLY HIGH elo without training or grinding if you have perfect game feeling, he is lying to you.
Try to play in a friends account who is hardstuck at gold/dia/plat. Sometimes I can't hit a single shot in their account and get <1 k/d. Meanwhile my main account peaks at Asc3, and my current alt account is ranked 2511 in europe. I really believe i can hit radiant, then i will delete the game because this is not a skill based game at all.
The difference with different elo accounts is huge! I mean, even the movement speed is different. I can prove that some Gold accounts move slower. It is so obvious but no one talks about.
This game literally alters your gameplay for 50% winrate. I am not even talking about rigged matchmaking system.
There is an algorithm in the game that decides for an interpolation window. What i mean by an interpolation window is each player's interpolation time window is different.
For example:
Player 1 has 100ms interpolation window,
Player 2 has 200ms interpolation window,
Player 1 starts spraying Player 2, lands 2+ bullets
100ms After Player 1 started spraying Player 2, Player 2 starts to spray back, lands 1 bullets.
But the server is interpolating up to 200ms in future for player 2, and 100ms later for player 1. In the interpolated future, player 2 has landed more bullets and killed player 1.
In player 1's screen she started spraying, landed multiple shots, then all of a sudden player 2 landed 4+ in an instant and killed player1.
People say this is a desync issue, but it is just a simple lag compensation.
The problem is, this lag compensation match rigging system changes every match/every round. To make the match longer or to make you loose or win.
I've experimented with artificial latency (clumsy) too. I even modified clumsy for activating packet delays on outgoing packets when i start to move, In some games this gave me a very large advantage. But in some games I just started to be glitching. One game was working fine with 50ms movement lags. And in the other game I was teleporting back.
This is how i figured out that my interpolation window was changing for every match and sometimes every round if i got k/d higher than 2.
cl_predict
Post by cl_predict » 12 Sep 2024, 17:39
XEM wrote: ↑
12 Sep 2024, 17:05
cl_predict wrote: ↑
09 Sep 2024, 16:47
For example:
Then how are we reaching radiant? We are the chosens ones?
XEM
Post by XEM » 13 Sep 2024, 17:35
cl_predict wrote: ↑
12 Sep 2024, 17:39
XEM wrote: ↑
12 Sep 2024, 17:05
cl_predict wrote: ↑
09 Sep 2024, 16:47
For example:
Luck, my main account moves slower and has serious hitreg issues. This alt account is somehow better, It almost feels like I am playing in better valorant servers where lag compensation is disabled.
cl_predict
Post by cl_predict » 14 Sep 2024, 03:42
XEM wrote: ↑
13 Sep 2024, 17:35
cl_predict wrote: ↑
12 Sep 2024, 17:39
XEM wrote: ↑
12 Sep 2024, 17:05
cl_predict wrote: ↑
09 Sep 2024, 16:47
For example:
There is nothing about luck when you can repeat it multiple time in a row. I also have terrible hitreg, no time to react, impossible to build muscle memory, getting instantly 1 taped on deathmatch while before I was hitting score like 40-6, 40-10 on a bad day.
I tried an electricity generator :lol:, few AIRBNBs in different cities, two countries. 4 different ISP in my country, including their FTTH and 4G/5G, every Windows optimizations, Windows custom ISO you can probably think of. I’m on a discord server with few 3k+ faceit elo players with this issue and they also still play at this elo …
jnzed
Post by jnzed » 16 Jan 2026, 15:25
cl_predict wrote: ↑
09 Sep 2024, 16:47
What was your pc exact pc specs that worked the best (minimal desync)?
Watchdog
Post by Watchdog » 26 Jan 2026, 00:03
UFO_Pilot wrote: ↑
17 Aug 2024, 12:35
z3rg1ch wrote: ↑
15 May 2024, 18:15
I dont know what to even think, after any tweak ang changing some settings and drivers my game changes. now I am in state where my enemies are not predictable at all, they are moving fast and not only when peaking also while changing direction its like faster than fast. When I see some vids of people playing they are almost in slo-mo when I need flash's superpowers to react and shoot. I am just thinking about leaving it (I mean competitive games). I will appreciate any kind of help)
I had a bit similar issue but the other way around, games would feel slowed down and funny enough easier to be played. But it was obvious something was off even comparing to vids of other peoples gameplay
After making some tweaks to try to get rid of bufferbloat to get from A to A+ on Waveform I noticed I had a few settings ON I didn't want which were task offloads.
Disabled all kinds of TCP UPD offloads and right after when I tried the games I normally play they looked and felt noticeable faster.
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
DisableTaskOffload 1
set-netoffloadglobalsetting -taskoffload disable
netsh int ip set global taskoffload=disabled
When TaskOffload is enabled on your system, it makes it easier to play? Is TaskOffload enabled the only setting that made it slower or faster? Or are there more settings? I would like to try it on my system.
