HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
Sz3ypy
Re: HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
Post by Sz3ypy » 19 Sep 2025, 19:14
I use Intel I210-T1 do far do good :D
Watchdog
Post by Watchdog » 20 Sep 2025, 04:39
Sz3ypy wrote:
19 Sep 2025, 19:14
Do you disable MSI priority on your i210 T1?
dermodemon
Post by dermodemon » 20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
JimCarry wrote:
01 Apr 2025, 16:33
hazzahodgson wrote:
01 Apr 2025, 14:58
JimCarry wrote:
01 Apr 2025, 14:46
thanks,but i still dont get it,you mean that when for example,when you go in msi util,msg limit when up or ?also when you plug the "realtek 8812bu" in the usb do you change any advanced settings on it or? and what is you cmd?
I guess you havent much experience with inteupts affinity/policies yet so id research it a bit before you change anything as you can easily make performance worse. it depends a lot on your hardware and how its configured.
Go in advanced network adapter properties and for rss queues, change msi limit for the same amount of queues you have. that make it a bit more stable for me.
however i do notice youre using the same ethernet controller as my motherboard has. You can try the netadaptercx driver. you can download it here https://www.realtek.com/Download/ToDown ... oadid=4342
-I guess you havent much experience with inteupts affinity/policies yet so id research it a bit before you change anything as you can easily make performance worse. it depends a lot on your hardware and how its configured.
i have i use i did put my nic on my last core.
-Go in advanced network adapter properties and for rss queues, change msi limit for the same amount of queues you have. that make it a bit more stable for me.
i dont use rss.if you increase msg limit for some driver and if the irqs dont go up as well it means it does not work.
-however i do notice youre using the same ethernet controller as my motherboard has. You can try the netadaptercx driver. you can download it here https://www.realtek.com/Download/ToDown ... oadid=4342
i use the latest one 2025 the one that you are linking i think is the same but with power savings enable or i am in mistake ?
https://www.realtek.com/Download/ToDown ... oadid=4357
try the one with netadaptercx, not the ndis one, i like netadaptercx one
Holy f*cking sh*t guys.
I beat desync with this "netadaptercx" driver.
I disabled all offload, energy savings and interrupt moderation.
Checked MSI box and put it to the core 4(priority low, msi limit 4, RSS 4 queues).
Then i put this command in CS2 launch options "+cl_tickpacket_desired_queuelength 0.035" without " ".
Now i don't have any desync and finally FEEL like my shots are hitting enemies as it should be.
Definitely not a placebo. Whole week without any kind of desync.
I am finally free from this network lag thread.
Such a relief.
P.S. tried USB network card = desync
tried PCIe network card = desync.
After all of that i came back to my onboard lan realtek NIC and with this driver my games (cs2 included) feel amazing again.
MOBO: Asrock B450m PRO4-F
dervu
Post by dervu » 20 Sep 2025, 10:24
dermodemon wrote:
20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
JimCarry wrote:
01 Apr 2025, 16:33
hazzahodgson wrote:
01 Apr 2025, 14:58
Such a relief.
Now tell if you tested on same game version to avoid update affecting your "feelings".
dermodemon
Post by dermodemon » 20 Sep 2025, 11:49
dervu wrote:
20 Sep 2025, 10:24
dermodemon wrote:
20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
JimCarry wrote:
01 Apr 2025, 16:33
Such a relief.
Well cs2 got updated 3 times this week. Still feels really good. By the way in the game called Hunt Showdown my desync disappeared too :)
Kal
Post by Kal » 20 Sep 2025, 18:04
dermodemon wrote:
20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
JimCarry wrote:
01 Apr 2025, 16:33
hazzahodgson wrote:
01 Apr 2025, 14:58
Such a relief.
Is this the driver with rss already disabled and not visible when you check the properties?
dermodemon
Post by dermodemon » 21 Sep 2025, 02:27
Kal wrote:
20 Sep 2025, 18:04
dermodemon wrote:
20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
JimCarry wrote:
01 Apr 2025, 16:33
Such a relief.
This driver has RSS enabled by default. I just change it to 4 queues
Watchdog
Post by Watchdog » 21 Sep 2025, 09:18
hazzahodgson wrote:
01 Apr 2025, 14:58
JimCarry wrote:
01 Apr 2025, 14:46
hazzahodgson wrote:
01 Apr 2025, 11:25
JimCarry wrote:
31 Mar 2025, 17:05
thanks for sharing / explain.i am on win 10 but what do you mean by "message interupts went crazy" ,also i wanto to ask can you give me link for the one you buy,and do you touch any settings on it,also cmd default ?
https://learn.microsoft.com/en-us/windo ... interrupts - you can read up on it here
the usb wifi dongle i have is a realtek 8812bu
Is there a driver for Intel I210-T1 that has "netadaptercx"?
Sz3ypy
Post by Sz3ypy » 22 Sep 2025, 13:55
Watchdog wrote:
20 Sep 2025, 04:39
Sz3ypy wrote:
19 Sep 2025, 19:14
Is on MSI mode but i dont remeber priority or undefined or high i think
InputLagger
Post by InputLagger » 08 Nov 2025, 22:35
dermodemon wrote:
20 Sep 2025, 11:49
dervu wrote:
20 Sep 2025, 10:24
dermodemon wrote:
20 Sep 2025, 08:03
hazzahodgson wrote:
01 Apr 2025, 23:34
Such a relief.
Still fixed till today?
