Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Sari
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Post by Sari » 08 Apr 2025, 11:33
pervysage19 wrote:
29 Mar 2025, 15:16
Just wanted to post about my experience in the hope that it may help someone someday who like me was just doing random Google searches every now and again tearing their hair out trying to figure out what was causing their issues.
The Issue: Floaty aim feel kicks in after playing a game for about 10-15 minutes or so and once it starts, will not go away until PC is restarted only for the cycle to repeat again. The floaty aim feel can be described as an almost accelerated sensitivity aim feel where the cursor is not feeling in sync with what I am trying to do with the mouse (clown cursor). Instead of feeling 1:1 it would always feel very slippery and inaccurate.
I tried basically everything and it seemed to even carry across different PC builds and even monitors (OLD build was a i7-8600K, 1080TI, 16GB 4133mhz RAM, CURRENT build is i9-13900KS, 4090, 32GB 7600mhz RAM). Older monitor was a 240hz ASUS PG258Q, current monitor is a 540hz ASUS PG248QP.
I have a triple monitor setup but with a two PC setup. Two monitors to my old rig, which I use for all purposes on the side and my new rig connected to ONLY the 540hz monitor and nothing else. The new rig is used strictly only for gaming for max performance and as to have nothing running in the background. I have always been very picky about going with lowest settings and maximum FPS, hence the 540hz monitor and overkill PC for 1080p gaming. I feel like I am very sensitive to changes in my setups and the floaty aim feel was absolutely killing my experience.
For reference I pretty much exclusively play Overwatch 2, uncapped frames NVIDIA Reflex Boost + On for lowest latency, 600FPS (max allowed on Overwatch) and in game I am usually holding a steady 580-600FPS with no issues at low settings. NVIDIA Control Panel: Ultra Low Latency Mode (gets overridden by Reflex anyways, Fixed Refresh Mode, Prefer Maximum Performance power mode).
So recently I had begun to notice that whenever the floaty aim feel would kick in, if I changed any NVIDIA GPU setting in the control panel, it would temporarily fix the floatiness for about a minute or so but it would immediately come back. I became convinced it was somehow GPU/driver related and tried changing every setting I could. Stuff like GSYNC would help it feel not as bad but you could still tell the floatiness was there a little bit.
Started messing with RivaTuner after I ran out of options in NVIDIA Control Panel to play with and I found that setting a frametime limit also felt a bit better but like GSYNC it didn't feel perfect and I hated the added input latency feel. Tried the scanline sync option and it felt much better than setting a frametime limit but I could still feel a hint of floatiness with that as well. Ended up giving up going down that road and un-installed Rivatuner. Back to square one with no solutions in sight.
Now I've had issues with electricity related interference in the past but won't go down that rabbithole as I don't think you can talk about that stuff here. But I have had excellent results having my entire PC setup running on a Medical Grade Isolation Transformer and implementing Quest VR fiber optic USB-C cables where ever possible. But this seemingly monitor/GPU related floatiness feeling just couldn't be resolved no matter what.
That is when the idea occurred to try a fiber optic DisplayPort cable. I was willing to try anything at this point and these things are relatively inexpensive on Amazon now if you can find one for a good price. Could always return it if it didn't do anything.
Got one in and replaced my regular copper cable immediately noticed a HUGE difference on the first day. Went a FULL day without any issues, great aim feel. On day 2, the floatiness seemed to come back which got me flustered. But then I began to wonder why it did seem like it was fixed for a day. Then I remembered I still have one more copper display cable going into my 540hz monitor that is connected to my old rig (basically sometimes I would use this HDMI connection to run all 3 of my monitors on my old rig). I unplugged that HDMI connection so that my gaming PC is strictly only connected to the 540hz monitor via the fiber optic DisplayPort cable and nothing else. So at this point the only thing connected to my 540hz monitor is the power brick and the fiber cable from my gaming PC. The great feeling from the day before immediately returned and now it stayed.
It has been two whole weeks now and the problem seems to be 100% fixed with certainty. The difference has been day/night and I am easily able to replicate the issue by introducing the copper cables back into my setup.
Totally bizarre and I don't know why it happens, but I am super grateful to finally have a solution to this longstanding problem that has been plaguing me for literally years.
Am not suggesting this will fix issues for other people as their symptoms or problems might be caused by completely different things, but for my situation it fixed the problem 100%. I am still in amazement and bewildered as to the why but I'm not complaining. Just been enjoying the feeling of gaming without dealing with stupid issues that no one else seemingly had to, it was so frustrating.
So yeah, hopefully this would help someone in the future!
From now on, I just use my 540hz monitor solely with my newer gaming PC via fiber optic DisplayPort cable and I use the old rig for my other two monitors.
Did you get the gold plated one or the regular aluminum one?
afn7
Post by afn7 » 08 Apr 2025, 12:18
Inputlagger91 wrote:
30 Mar 2025, 06:31
Good afternoon, everyone, I'm from Russla, I use a translator. Yesterday I came across this post and was very interested in this story, today I bought an hdmi optic cable and at the moment I'm going home and I'm going to test it. I'll write my impressions later.
I had this one also. Shitty quality. Did not solve anything. I just wanted to warn you. Return it if you can.
Asus Rog Strix z590 Gaming E
Intel I7 11700k
Corsair Vengeance lpx 32gb 3600mhz cl16
Msi RTX 3060 TI Ventus 3x OC
CM Power supply 750w 80+ Bronze
kyube
Post by kyube » 08 Apr 2025, 12:30
To add onto this topic, here's a pure-optical fiber cable review & a hybrid-optical fiber cable analysis, take a look at these videos:
pervysage19
Post by pervysage19 » 08 Apr 2025, 22:16
Another week has gone by and my problem from the original post is still fixed. I am fully confident that whatever issue I was having in regards to floaty aim is now gone and it's very easy to reproduce by bringing back my default monitor cable I was using before.
As for all the unstable RAM talk, I know for a fact that is not my issue. In fact, I have in the past tried swapping in slower, more "reasonable" RAM like 2133mhz I believe it was. No difference.
I feel like I should repeat this once more as for some reason people always see these posts and claim fake news or that I am out to sell some snake oil. I said from the beginning, by no means is this a one-fit-all solution. Everyone will have their own issues and source of this so-called floaty aim feel... it's never the same cause for everyone.
This was more so as an idea for someone who is at their wits end and has tried all other options and possible causes. Just something worth looking into... especially since it's an inexpensive cable these days (not necessarily for everyone... people in different countries might have a harder time accessing these at a reasonable price). And over here in Canada and probably the USA, it's super easy to return stuff to somewhere like Amazon if it doesn't work out.
If there's even one person in the future that comes across this post from a Google search or something and it actually helps them out... well this post has done it's job :mrgreen:
Most of these fiber optic hybrid cables should honestly be the same... but the one I used was DisplayPort and was linked earlier. Can't really speak to the quality or difference in other cables... but theoretically they should all be the same.
pervysage19
Post by pervysage19 » 08 Apr 2025, 22:21
Sari wrote:
08 Apr 2025, 11:33
pervysage19 wrote:
29 Mar 2025, 15:16
Mine was the black cable with silver housings and gold plated connectors.
I would think that it doesn't really matter but they do seem to be priced differently over here with the black one being more expensive. Can't speak to whether one would be better than the other in any significant way.
JimCarry
Post by JimCarry » 09 Apr 2025, 14:03
pervysage19 wrote:
08 Apr 2025, 22:16
but there are not,when you buy monitor it comes with dp cable,maybe you are right you must buy another dp cable,and not use the stock?
amorou
Post by amorou » 09 Apr 2025, 14:25
So I tried a fiber hdmi (8k capable)
Mouse was maybe little little little bit more accurate but much more laggy aswell (laggy similar to gpu scaling vs display scaling)
Again I dont have grounding and there is two converters on the cable u know
Image quality became sharper tho. Returned it anyway
Sari
Post by Sari » 09 Apr 2025, 17:05
amorou wrote:
09 Apr 2025, 14:25
which scaling is better for u the display or gpu ?
amorou
Post by amorou » 09 Apr 2025, 17:16
Sari wrote:
09 Apr 2025, 17:05
amorou wrote:
09 Apr 2025, 14:25
Display scaling has lower lag on every setup I tried
However gpu scaling makes games visualy better when fps is not locked to hz. ( Less %1s? idk)
I always prefered display scaling
pervysage19
Post by pervysage19 » 10 Apr 2025, 00:18
amorou wrote:
09 Apr 2025, 17:16
Sari wrote:
09 Apr 2025, 17:05
amorou wrote:
09 Apr 2025, 14:25
Just to pitch in my 2 cents as well, I agree with your finding on Display scaling.
Ever since I got the 540hz ASUS, for whatever reason, Display scaling felt way superior in terms of feeling "lower lag".
