InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
Sandy
- RealNC
Re: InputLag SOLVED Realtek USB / TP-LINK UE300 USB 3.0 Adapter
I deleted this link. Can you explain what it was for?
Lev1n
Sandy
- RealNC
You've posted a link pointing to a custom port of a random server disguised as a github link.
wasted42
Unfortunately, the problem came back. I fell into depression because of it, i didnt visit forum and didnt give update, sry
Sandy
Yes, the network card did bring about a change for a while, but now the input lag has returned. This is likely a problem with the chipset or the operating system.
Kipperii
I was similar. On the first day, things improved a lot; I could kill everyone. But then the problems slowly returned. Even so, overall, the USB Ethernet is still about 10% better than the onboard network card, and it's something worth investing in.
MontyTheAverage
MontyTheAverage
We are just spinning back to the same old threads. the input lag/desync issue exists on different chipsets, diffirent operating systems and also exists on consoles. Mouse/keyboard/controllers. Doesn't matter. At this point, look anywhere but hardware/software.
