Page 6 of 8
Re: Acer announces 144hz IPS 1440p G-SYNC! [XB270HU, XG270HU
Posted: 25 Feb 2015, 19:34
by masterotaku
I expected much worse about input lag. Im very impressed
. The lack of overdrive artifacts is also great. BenQ, look at it and learn.
However, the lack of 3D and ULMB at 120Hz kills me. I guess the Predator (3440x1440, 21:9, 144Hz) one won't have them probably
Posted: 26 Feb 2015, 20:03
by mutantmagnet
Honestly I don't see the inability to use ULMB at 120hz as not a big deal. What made me excited for ULMB over lightboost is that the barrier to getting near zero motion blur was lowered from 100fps minimum to 85 fps minimum.
With ULMB attained on an IPS panel the only thing that could be better now is a VA version from Eizo.
Posted: 26 Feb 2015, 22:08
by flossandgrindwillis
Would this be a viable alternative to a cheaper 1440p monitor like a QNIX?
Posted: 26 Feb 2015, 23:24
by flood
more the the qnix is NOT a viable alternative to this
well not really "better"
unfortunately ips vs va is a tradeoff of viewing angles and contrast ratio
Posted: 27 Feb 2015, 13:23
by BCShak
What sucks now is that the date on
http://www.overclockers.co.uk/showprodu ... =MO-077-AC
Changed from March 28th to April 15th
I can't wait that long with the equipment I have now!!!
Posted: 27 Feb 2015, 14:19
by mutantmagnet
After what happened with the swift you better hope there aren't supply constraints. This will be the first time I'm preordering hardware.
Posted: 27 Feb 2015, 14:41
by BCShak
mutantmagnet wrote:After what happened with the swift you better hope there aren't supply constraints. This will be the first time I'm preordering hardware.
I'm REALLY tempted. But after the conversion, it's still almost $1000!!!
I'm thinking, maybe I should wait until a preorder is available in the US, but that may not happen until after it's available in the UK, which is BS!
Posted: 05 Mar 2015, 17:03
by aaron5
Does anyone know the difference between the XG270HU and the XG277HU, if any?
Posted: 10 Mar 2015, 11:04
by mutantmagnet
Posted: 11 Mar 2015, 04:52
by Beavergum
It feels good, it feels really good knowing I can hit that buy button! Now I've got just a little more of a wait!
