Really? That's awesome. Does the cloned video look normal when the framerate is less than 144 and the G-Sync is kicking in?Cinder wrote:I have a 980 and the Asus PG278Q G-Sync monitor. I have to lower my resolution to 1080p to clone my display over to the Avermedia card I have and G-Sync seems to work with cloning. At least my FPS in Battlefield 4 stays ~144, as it does without cloning the display and the game still feels smooth.
Apparently capture card options are pretty limited when you have a G-Sync displayOnly option I can think of is the Datapath DVI-DL and cloning the G-Sync display over to it...
I'm waiting on the next gen Nvidia cards, be it 980Ti or Titan or whatever they decide to call it and get two of those. I read somewhere that you can't clone displays when using SLI, so that might be show stopper for the only capture card option.
And if you'll check my computer specs: http://www.twitch.tv/boildown, the DVI-DL is precisely the capture card I'm using now.
