MSTAR ISP rent/buy/sell/trade [upgrade BENQ to V2 firmware]
naivaklam
Re: MSTAR ISP rent/buy/sell/trade [upgrade BENQ to V2 firmwa
Post by naivaklam » 10 Apr 2014, 13:27
hi, im also interested in this tool (im from germany). if some1 can tell me where to get it, id appreciate it
kuschluk
Post by kuschluk » 10 Apr 2014, 13:38
koriwi wrote:@Kuschluk
Ich habe keine Berechtigung meine PM's zu lesen o.O
wenns ok ist, schreibs hier
Ich habe den Programmer verkauft (habe es auch hier gepostet)
I have sold the programmer allready (posted it here, too)
=> the seller,where I purchased it doesn't offer it @ www.cart100.com anymore sry.
Post by Chief Blur Buster » 10 Apr 2014, 16:43
This is the most reliable and recommended MSTAR ISP, the same one that BENQ sent to me to flash my XL2720Z to V2:
http://cart100.com/Product/18092359047/ ... g_Tool_US/
(900+ units in stock, at the time of this writing)
t00n
Post by t00n » 10 Apr 2014, 19:51
Hi fals einer von euch das Gerätchen nicht mehr braucht würde ich es gerne abkaufen :)
mfg tobi
naivaklam
Post by naivaklam » 11 Apr 2014, 17:42
one question, since it seems hard to get that MSTAR ISP in germany: ive just read the manual for doing that update by yourself. is it right that i just need this
and a vga cable? and if so, whats this called? LPT-D-Sub adapter or something? :p
Necro
Post by Necro » 11 Apr 2014, 18:16
Hi all! I've been reading this forum for a while and really appreciate the wealth of knowledge. Just wondering whether anyone has managed to get an MSTAR ISP in the EU and is willing to sell it on? I am in the UK.
I have ordered the XL2411Z from Amazon and when it arrives I'm fully expecting it to be version 1.
Lakam
Post by Lakam » 12 Apr 2014, 05:01
@naivaklam Ich schreibe dir einfach mal auf Deutsch. Geh einfach mal zu Conrad Elektronik oder änlichem und zeige denen diese Liste:
Selbstbaugehäuse 9/25 Polig
Widerstand Metall 0,6W 1% 75R BF 020 x2
Transistor BC 337-25 T092 DIO x2
SUB D Buchsenleiste 15 Polig 3-Reihig (weiblich/female)
Stiftleiste 25 Polig (männlich/male)
Schaltlitze LiY, 5m oder länger (Leitungen)
Wenn du diese Artikel erworben hast (kostet circa 6,50), lötest du die Leitungen exakt wie auf dem Bauplan angegeben. Das Gehäuse brauchst du nicht unbedingt, sieht mit Gehäuse natürlich hübscher aus.
naivaklam
Post by naivaklam » 12 Apr 2014, 09:40
Lakam wrote:@naivaklam Ich schreibe dir einfach mal auf Deutsch. Geh einfach mal zu Conrad Elektronik oder änlichem und zeige denen diese Liste:
vielen dank. mir is jetz grad aufgefallen, dass mein pc gar keinen anschluss für LPT am PC habe :/
kanns also wohl vergessen, oder?
Lakam
Post by Lakam » 12 Apr 2014, 10:00
Ich glaube ich hatte im Forum gelesen, dass es eventuell mit einem hochwertigem LPT zu USB Adapter funktionieren könnte (sicher bin ich mir da nicht). Falls dein Rechner also die LPT-Schnittstelle nicht hat, müsstest du mal nach einem älteren Laptop schauen oder bei Bekannten nachfragen. Falls wirklich keiner diesen Anschluss hat, wird es wohl leider eher nichts.
naivaklam
Post by naivaklam » 13 Apr 2014, 16:21
ok, werd hoffentlich n anderen pc finden
