Page 6 of 8
Re: HUGE Fix at Input Lag!!!!
Posted: 05 Feb 2021, 03:31
by secretiveolwagner
pox02 wrote: ↑
01 Jan 2021, 19:48
dwm bypassed in warzone :D
Can you please explain how did you enable fullscreen in Warzone? I downloaded your vsync .nip file and when I temporarily disabled DWM I can launch Warzone but it won't allow me to set it to fullscreen mode, my monitor would go black screen for few moments then Warzone reverts it back to fullscreen borderless. I tried it on Windows 7 as well but I got the same result plus the game became really laggy (even though I got similar FPS compare to Windows 10 performance)
I'm on Windows 10 20H2 btw
Posted: 05 Feb 2021, 12:42
by forii
to the OP
can you tell exactly what u did to disable "dwm" mouse movement lag? i hope u
If i checked correctly you need to have nvidia inspector? + extrememouseinputnovsync.nip?
Im kinda confused, does it work on win 10 or its only for win 7?
Posted: 05 Feb 2021, 12:59
by forii
pox02 wrote: ↑
27 Nov 2020, 05:37
i want share 2 nips one for gsync and other no vsync monitors
bypass dwm in nvidia driver
make sure all those 3 on 1
Gsync monitors change framelimiter v3 to ur hz
240hz 236 fps 180hz 176 fps 144hz 138fps
no vsync nip use 0x4 which is flip for more snappy movement in game u can change to v2off + disallowed for lower input but i like more smooth game movement with non vsync
gsync=http://www.mediafire.com/file/fkoiutr32 ... c.nip/file
nonvsync=http://www.mediafire.com/file/l8nkpt4gs ... c.nip/file
if my monitor is g-sync compatible and I dont use g-sync or any form of v-sync should I take g-sync NIP or nonvsync?
Talking here on win10 ofc
Posted: 05 Feb 2021, 13:39
by forii
pox02 wrote: ↑
15 Nov 2020, 20:42
if u want really low input lag for overwatch try my settings :)
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow :)
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
And how does it work with Nvidia Reflex Time? (ENABLED + Boost In call of duty game settings) - Should we also keep it off like in nvcp?
I had my MCFORCEHOSTSTAGINGBUFFERSIZE to x0.000000 default so idk if I should change it
Posted: 06 Feb 2021, 05:18
by dbc_lx
The two settings mentioned regarding frame rate limiter disallowed etc. dont work for me on the latest nvidia profile inspector with latest drivers - i get an error when trying to hit apply - am i doing sth. wrong?
Posted: 06 Feb 2021, 09:00
by BTRY B 529th FA BN
Posted: 07 Feb 2021, 07:27
by chenifa
dbc_lx wrote: ↑
06 Feb 2021, 05:18
It's the newer drivers, they don't allow to change it anymore
Posted: 07 Feb 2021, 09:28
chenifa wrote: ↑
07 Feb 2021, 07:27
dbc_lx wrote: ↑
06 Feb 2021, 05:18
I'm guessing it won't work on RTX 3000 series?
Posted: 08 Feb 2021, 00:15
by forii
Well Im on 460.89 nv driver, win 10 2009 ver 19042.746 + rtx 3080 and this works for me:
Posted: 08 Feb 2021, 22:05
forii wrote: ↑
08 Feb 2021, 00:15
This is weird, I have a RTX 3090, I get the exact options like you have in the screenshot on Windows 7 but not on Windows 10 20H2, Which nvidia inspector are you using?
