Hi guys like I have this issue since 3 yr
I know it exists because on aimbotz CSGo I get Times with deag like kioshima (normal settings no flex)
And when I have this issue I get constant plus 10 s
People call me either bot or cheater
Because they believe it’s an excuse my lag
Idk some magical days once a year it’s off so I did 20-0kd in a wingman and 17-1 18-2 after that
I remember it
I played against a French pro on my lap where this issue comes after some time and I did 17-0 kd and then issue came -we lost I think he even was on stream and said :this guy
And I honestly asked my mates are those bots ?
At that time I didn’t even know this was a pro
So I believe there’s so much to lag hitreg delay etc
And I’m tied for people calling me bad and saying it’s placebo thats why I had to tell this here not to show off or flex (pls I’m not that guy)
I put more than 4K hrs time in alrdy in trying to fix
Espacially in CSGo I instant know it when I have it like when I shoot chickens they don’t die sometimes I need 3bullets (they are less than 1hp) but I see bulletholes when I watch demo it looks like I didn’t even shoot that direction even when I stood still and shoot slow...
Vents don’t break or like bullets go through or dissapear also it seems like I’m easier to hit because I change wasd slower
Also I die a lot without seeing Sb when he’s peaking (and don’t shit me I’m global ,when ur off lags u can even control each bullet in a spray)
On a certain map (mirage) there a space where u can jump out without breaking vents and every time I got them I don’t make it
But on my lap it’s ok for 5min I play
And when I shutdown disconnect battery and power and press down
So it’s fixed for like 5min
So I believe it’s sth like cmos RAM
Or some transistor is faulty
It could also be that Theres a Spike which kills sth and then u get the problem
Like if cpu spread spectrum ist working anymore or sth like that
Because I tried 4 cpus 4gpus memtest ran etc everything else also different boards etc
240hz Monitor constant over 500fps with an i9
Fabless psu for 250 I also tried
Like I have 5 mice etcetc etc even Keyboard
My 8000hz mouse lags even in 4000hz mode in all games I play
(Idk one night it was like was gone for one day after I connected the second 4pin cpu)
And that night I watched like the usage of my cores and it was like changeing all the Time and they al were more like balanced... at 40-60 percent
EG in warzone I get often lieb 4 cores at 100 percent and the other 4 at like 0-6 percent etc
I tried single ram slot it was better
I tried oc ram even 5ghz
Even once 1.7v nothing changed
Tried like 98percent out of bios (Asus and MSi)did fr33thy tweaks etc tried windows ami, Win 7 , and on my lap even Linux
My cpu is right now not in my pc so if Sb could try start pc without cmos battery would be great
I got my pc to 4different friends (Germany) and they are very far away
But recently I remembered they all had solar Penels
I also tried different sockets I earthed with my water heater in my room (the 3wire )
Then I earthed the pc case
I build a semi faraday cage but soon I’ll build a real one
Also a emi purifier
All it didn’t help and I have also very expressive audio equipment where I have no issue at all
I’ll buy a seperate rod which I can put in the ground and wire to my window to my pc cable
I tried without groud (idk that’s very stupid)
Also to me ps2 lags completely Ingame when I’m in Win ok but Ingame it’s like staying when I move fast
So I Wonder why is it that all my 4cpus have proplems processing data first(real-time)rather than wait with a normal mouse
What helps for me :
-don’t Play high Tick servers eG 128 because it makes it even worse
- play with mouse 125hz same for keyboard
-disable audio in bios and use seperate audio card
-a very low mouse acc makes the hitreg somehow better cause I believe the input gets calculated more and has a higher priority
-use single core in games
-rawinput off for me it’s better
-late night problem gets less like at 3am
-low FPS and low hz better
-when one core over 50 percent it usually gets worse
-watch if ur cores are like Changeing and not like more static that some cores are near 0 usage always (ofc first cores are higher all time)
-disable as many services as u can
-Limit CPU usage process Lasso etc
-change different drivers to high /real-time every time
And don’t ask fiver or other people like me, I wasted a lot of money at least 300for support
And this a long ass answer
But doesn’t even show what I have experienced
And what I have tried -btw sorry for my english
And I’m litterly done but I will sacrefice my fckn life to it and I’ll find a solution... for all of u
I’ll be surprised how much u hit Ingame even when it looks like ur not even on the target cause usually the monitor should lag after xD
