BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
marwan
bro i want to know which firmware do you use and the exact steps you did to make it work because it gives me out of range notification for few seconds then screen turns black
Maxinator500
V2 or V3 fw is required.
Update is only possible via DVI monitor port. You can buy a cheap HDMI/DP to DVI adapter from amazon if your graphics doesnt support DVI. Then you'll need to use linux enviroment (live usb would go) to run flashrom utility. I can get you the compiled flashrom I have, so you could just "chmod +x" the executable and proceed to flashing.
Then OOR buster will work.
Let me know if you need the files.
Mustis
Can someone reply a guide how to overclock xl2411p to just 190-200hz, appreciate it!
Maxinator500
Oh wow -- that's one of the most glitch-free 260Hz overclock of a 144Hz BenQ.
No frameskipping at www.testufo.com/frameskipping ?
bakn4
kwuic
My XL2411p just doesn't seem to be able to bypass the out-of-range error at all. is this cause of a bad firmware version or what?
Maxinator500
kwuic
Okay.. so how do i do a rollback. I cant find advice anywhere, thank you.
spinzo
no frameskip at all its all goodChief Blur Buster wrote: ↑03 Apr 2025, 19:17Oh wow -- that's one of the most glitch-free 260Hz overclock of a 144Hz BenQ.
