Page 54 of 55
Posted: 20 Feb 2025, 07:37
by marwan
bro i want to know which firmware do you use and the exact steps you did to make it work because it gives me out of range notification for few seconds then screen turns black
Posted: 20 Feb 2025, 15:33
by Maxinator500
marwan wrote: ↑
20 Feb 2025, 07:37
V2 or V3 fw is required.
Update is only possible via DVI monitor port. You can buy a cheap HDMI/DP to DVI adapter from amazon if your graphics doesnt support DVI. Then you'll need to use linux enviroment (live usb would go) to run flashrom utility. I can get you the compiled flashrom I have, so you could just "chmod +x" the executable and proceed to flashing.
Then OOR buster will work.
Let me know if you need the files.
Posted: 22 Feb 2025, 10:52
by Mustis
Can someone reply a guide how to overclock xl2411p to just 190-200hz, appreciate it!
Posted: 22 Feb 2025, 14:47
by Maxinator500
Mustis wrote: ↑
22 Feb 2025, 10:52
There's no need in a guide as CRU usage posted on its home page at monitortests.
Posted: 03 Apr 2025, 19:17
spinzo wrote: ↑
06 Feb 2025, 11:39
I managed to achieve 260Hz 1280X720 on the BenQ XL2411P with DP
Oh wow -- that's one of the most glitch-free 260Hz overclock of a 144Hz BenQ.
No frameskipping at www.testufo.com/frameskipping ?
Posted: 20 Apr 2025, 16:45
by bakn4
KATT wrote: ↑
08 Aug 2023, 06:50
Hello, windows defender states that Oorbuster.exe is a trojan, anyone have any info why windows warns about this?
I could not find anyone else having this problem, thanks in advance.
Trojan:Win32/Zpevdo.B
its malware, use the other version
Posted: 04 Jun 2025, 12:35
by kwuic
My XL2411p just doesn't seem to be able to bypass the out-of-range error at all. is this cause of a bad firmware version or what?
Posted: 06 Jun 2025, 00:00
by Maxinator500
kwuic wrote: ↑
04 Jun 2025, 12:35
Yes, the fw version has to be below V6. Do rollback.
Posted: 08 Jun 2025, 07:49
by kwuic
Maxinator500 wrote: ↑
06 Jun 2025, 00:00
kwuic wrote: ↑
04 Jun 2025, 12:35
Okay.. so how do i do a rollback. I cant find advice anywhere, thank you.
Posted: 24 Jul 2025, 18:03
by spinzo
03 Apr 2025, 19:17
spinzo wrote: ↑
06 Feb 2025, 11:39
no frameskip at all its all good
