Cutsman
Post by Cutsman » 31 Mar 2022, 09:37
Question for those of you using two of these panels for dual-screen setups. Do you guys use different settings for each panel? Like one is dedicated for gaming and the other for general desktop use?
| ASUS VG259QM 1080p @ 280Hz OD120 IPS |
DukeDice929
Post by DukeDice929 » 12 Apr 2022, 18:00
Looks like RTINGS.com recalibrated color profile for VG259QM: review.
Old RGB settings were: 97-100-95
New RGB numbers: 100-98-91
Brightness (17) and contrast (80) are still the same.
Also icc-profile now can be downloaded directly from the link in the review. I suppose it was changed too (old 6.80KB vs 6.71KB new).
thanks to this post: viewtopic.php?p=80042#p80042
My bad English :0
Max_hz
Post by Max_hz » 13 Apr 2022, 06:39
DukeDice929 wrote:
12 Apr 2022, 18:00
Another difference in their test results; as most of us already used OD 120 (thx axaro1), they now also recommend OD 120 with the new test method, while that was still OD 60 with the old test method.
GOR1L4
Post by GOR1L4 » 16 Apr 2022, 18:39
DukeDice929 wrote:
12 Apr 2022, 18:00
What is an ICC profile? does it make much difference? I tried to install seeing tutorials but not feel differences in colors.
GoyoXP
Post by GoyoXP » 25 Apr 2022, 23:06
Hey guys, just bought a VG259QM and i am using on Racing Mode with user colors R - 97 G-94 B-97, brightness 60 and contrast 80, tried a bunch of configs, but nothings come close to my previous XG2401. I found strange that VG259QM is a IPS panel and XG2401 is a TN.
The colors on XG2401 looks more vivid, stronger, black is more intense. On VG259QM colors looks more real,but weaker,yellowish and darker.
I tried to mess with constrast, brightness but could not make look like my TN panel.
Why this is happening? Maybe my eyes isn't used to new panel yet? Can i make looks like the other?
Thanks
KoRsaR
Post by KoRsaR » 26 Apr 2022, 04:54
GoyoXP wrote:
25 Apr 2022, 23:06
Thanks
Hi, i dont know what my problem is, but all settings from any site isn't working for me (everything looks dark and green with settings from rtings), try settings what i did by myself
Racing mode
R-96 G-62 B-65
Brightness 40 Contrast 80
Its a bit reddish, but still better then acid green
GoyoXP
Post by GoyoXP » 27 Apr 2022, 18:55
KoRsaR wrote:
26 Apr 2022, 04:54
GoyoXP wrote:
25 Apr 2022, 23:06
Thanks
Racing mode
R-96 G-62 B-65
Just tried your settingws but didn`t like it, on mine monitor gets even more yellowish than before, but thanks for your input.
I read that some people could be more sensitive to matte display, maybe this is my problem and yours too.
coolturtle4
Post by coolturtle4 » 02 May 2022, 01:30
Hello, what settings do you recommend for Apex Legends for 189 FPS?
Scr1pts
Post by Scr1pts » 09 May 2022, 16:41
Hi @axaro1 what overdrive is best for 240hz? And can I see the chart of od120 at 240hz
axaro1
Post by axaro1 » 10 May 2022, 01:41
Scr1pts wrote:
09 May 2022, 16:41
OD60
Scr1pts wrote:
09 May 2022, 16:41
I can't because I'm using RTings response time tables that are limited to 280hz.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
