Posted: 16 Jun 2020, 23:22
Would you consider the Acer Predator XB273 X if you had an AMD card?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
which says input lag is instantaneous because the XB273 X is a G-Sync monitor. Did you measure the input lag using the Oscilloscope? Surely you are not suggesting that any G-Sync monitor has zero input lag. Human perception isn't good enough, we need hard evidence and numbers. Also, input lag at 60 fps is nice for consoles, but that is not my concern here. I am only interested in 240 Hz numbers.RLCScontender wrote:
I'm not a fan of 27" 1080p, the MSI is still one of the best if not the best 24.5" 1080pWayUpGaming wrote: ↑16 Jun 2020, 19:53damn man, now you're making me regret ordering the MSI MAG251RX lol....the Acer was on sale too and I passed up on that for this one due to your recommendation earlier, I had a feeling this Acer monitor was gonna be a beast!
If you can get more than 250fps every single time just set refresh rate to 280hz and cap at 250fps with freesync.Kryptik wrote: ↑16 Jun 2020, 18:44
Ok so for example if I can't get more than 250 fps in quake than the best thing to do is use 240hz (or 280hz?) with freesync + 250 fps cap
or use 240hz and cap the fps at 236?
Which method should offer the least input lag or doesn't really matter?
Also what do you guys think of the VG259QM colors for an IPS?..I've been seeing some reviews suggesting its colors are good but aren't that great compared to other IPS monitors so some clarification as to what exactly that means would be nice.
how much did u pay for the xb273x gsync module?RLCScontender wrote: ↑16 Jun 2020, 11:03CANCEL YOUR PRE ORDER AND GET THE PREDATOR G-SYNC MODULE.Spacepotato87 wrote: ↑16 Jun 2020, 10:07awesome comparisons! Honestly, you should get a Benq XL2746s or XL2546s to compare the fastest TN vs fastest IPS. Its still unclear how the best TN performs against the best IPS.RLCScontender wrote: ↑15 Jun 2020, 19:51*****Breaking NEWS*****
My replacement acer predator xb273 x came today. My previous one was badly tuned(it wasn't tuned at all, it was stuck at the Acer nitro XV273x OD tuning. (acer rep from canada informed me via youtube and had me send it in for a replacement.
This is the one they sent me and, the TUNING is excellent. This predator JUMPS a lot of monitors it should be in the very top. I will use two oscilloscopes for this because my cheaper digital oscilloscope is can't give me consistent rise/fall times.
I will do a double review coming up with the vg259qm and the acer predator xb273x since they arrived relatively close to each other. And how they fare against the beast MSI MAG251rx.
but yes, these THREE(FOUR if you count the vg279qm) are the fastest 240hz(280hz on the asus) IPS monitors.
Peak performance
1. Asus TUF VG259qm
2. Asus TUF VG279qm
3. MSI Optix MAG251rx
4. Acer predator xb273x
5. Dell Alienware AW2521HF
6. Dell Alienware AW2720HF
Response time to overshoot ratio
1. Acer predator xb273x
2. MSI MAG251rx
3. Dell Alienware AW2521HF/AW2720hf)
4. Asus VG279qm
5. Asus VG259qm
Acer Predator xb273 x (clickable)
MSI Optix MAG251rx (clickable)
heres all 3 UFOs on the acer predator
This monitor IS probably the best monitor i've ever tested in my entire life.
want to see sub 2.6ms response times with 0% overshoot and basically 0-1ms input lag?
("like new" "item will come in original packaging) but failed to describe the horrendous backlight bleed and dead pixel.
(this image isn't faulty, those ugly buttons are individual pixels. Also, if you look closely, you can easily see the dead pixel)
