LG 27GK750F-B - 240Hz, 27" 1ms Blur reduction, Freesync
k2viper
Post by k2viper » 26 Apr 2019, 05:31
shekel wrote:This depends on the monitor, I've had mine go off every 20-30 seconds, so I just lowered horizontal totals by a little bit more.
When it starts to lose sync yes, it is going off every 20-30seconds until you powercycle it. After this it works fine for some days or even weeks, depending on how often you open OSD.
addi
Post by addi » 26 Apr 2019, 08:11
Well seems like LG is not really working on the problem, we posted in their forum.
It's almost 2 months ago now.
I could be wrong but we dont get any information whatsoever.
Even the first reply, we only got it, cause someone was actually asking.
I wish they would provide us atleast some Information, what is actually going on.
skri170392
Post by skri170392 » 26 Apr 2019, 09:52
this appears when I activate the response time, should I take it as a guarantee? https://youtu.be/cFQrsPsFD40
PD: sorry for my bad English..
k2viper
Post by k2viper » 29 Apr 2019, 08:42
skri170392
That's not normal. Probably yes, you should RMA it.
ericl
Post by ericl » 29 Apr 2019, 12:47
I noticed that sometimes. Turning it off and back on fixes it.
skri170392
Post by skri170392 » 29 Apr 2019, 13:25
yes but it is very annoying to turn it off and turn it on to fix it, ya enough lg, i pay $ 520 US dollars for this? LG never again!
aJam
Post by aJam » 06 May 2019, 02:41
I've read through all this topic and it's still very hard to decide if it's a good monitor or not. I have XL2411z now and ordered this LG today. It will be interesting to compare both in non MBR mode, as I usually not use it. If Solid Lad wouldn't hate it so much, my mind would have been easier.
A Solid lad
Post by A Solid lad » 10 May 2019, 11:12
aJam wrote:I've read through all this topic and it's still very hard to decide if it's a good monitor or not. I have XL2411z now and ordered this LG today. It will be interesting to compare both in non MBR mode, as I usually not use it. If Solid Lad wouldn't hate it so much, my mind would have been easier.
haha, sorry for the inconvenience :D
I was upgrading from an XL2411Z as well.
Motion will be smoother, that's for sure, and since you haven't tried other (better) 240hz displays like the xl2740, xl2540 or aw2518hf you might even be fully satisfied with the LG.
But going back and forth between my old 2411 and the LG, I noticed that I was doing better even with the old Benq, because of the lower input lag.
Discord | Youtube | Twitch
k2viper
Post by k2viper » 12 May 2019, 10:49
A Solid lad wrote: But going back and forth between my old 2411 and the LG, I noticed that I was doing better even with the old Benq, because of the lower input lag.
Afair you havent tried the Original scaling mode that time you had LG in hands?
Now it is known for sure that Original is the lowest lag mode.
aJam
Post by aJam » 13 May 2019, 08:17
I got the LG, set up as advised. I'm running with g-sync on, so no MBR. I haven't noticed if the input lag is higher, but I set it to Original scaling from the start. I will try to change it to check if I see the difference.
However, I really like this monitor. Bigger screen size, nicer colors, g-sync etc. an all round improvement from XL2411Z.
