Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Shade7
Post
by Shade7 » 23 Jun 2022, 17:33
kokkatc wrote: ↑23 Jun 2022, 01:25
For Windows 11 I recommend you download 'timer resolution.'. Some ISLC builds for some reason don't always work on 11. Google for download link, timer resolution. Remember to run as admin.
Do u recommend the one by Lucas Hale?
If so, are you using the free or paid version?
kokkatc
Post
by kokkatc » 23 Jun 2022, 18:33
Shade7 wrote: ↑23 Jun 2022, 17:33
Yes, that's the one I use. The free version should work.
Shade7
Post
by Shade7 » 23 Jun 2022, 19:00
kokkatc wrote: ↑23 Jun 2022, 18:33
It says it's for windows vista + windows 7.
Is the download link on the website broken? Nothing happens when I click on it. Tried multiple times & 2 different browsers.
Shade7
Post
EDIT: finally worked - had to use edge I think.
Post
by Slender » 23 Jun 2022, 20:00
Shade7 wrote: ↑23 Jun 2022, 19:00
it would be nice to know about the benefits of version 2.0, is anyone willing to take a chance and buy it?
Shade7
Post
by Shade7 » 23 Jun 2022, 21:05
Slender wrote: ↑23 Jun 2022, 20:00
I used to have it 2 years ago. Nothing special- didn’t work any differently in my opinion. I switched pcs since then and tried to reach out to them for a new download link- since the one I purchased said it had expired. They never got back to me.
Post
by Slender » 24 Jun 2022, 10:53
- 3324324.PNG (58.14 KiB) Viewed 12089 times
Melkxz
Post
by Melkxz » 24 Jun 2022, 18:16
0,5 timer resolution doesn't do anything positive on my build : revios 11 (+tweaks) : disabledynamictick+useplatformtick yes / ryzen 5600x
I have never felt a positive impact on input lag with ISLC or timer resolution/timer resolution service (at the best it didn't do anything.
Shade7
Post
by Shade7 » 24 Jun 2022, 18:51
Melkxz wrote: ↑24 Jun 2022, 18:16
Why bother with disabledynamictick or useplatformtick. Why not just default?
ptuga
Post
by ptuga » 25 Jun 2022, 11:05
I was actually curious about revios 11. Tried it on my other SSD, benchmarked a couple games. Exact same performance. Shadow of tomb raider usually scales with everything, still. Got 300 cpu game average, vs 296 on regular windows 11 22h2 with lowest settings dx12.
Didn't bother to check gpu bound scenarios, but if anything it would show on cpu/ram bound.
Mouse felt the same...
I think costum os are not worth it. Just install windows, remove all the BS, disable services and it's done.
