It is the body that causes issues
Locked
internetexplorer4
Re: It is the body that causes issues
Post by internetexplorer4 » 29 Jul 2024, 00:37
InputLagger wrote: ↑
28 Jul 2024, 21:22
internetexplorer4 wrote: ↑
27 Jul 2024, 12:13
DrivenCrazy wrote: ↑
27 Jul 2024, 03:43
cursed-gamer wrote: ↑
19 Feb 2024, 12:04
Man, I was playing in China however I live in Europe. Couldn't hit shit anyway.
Is it with the same PC or not? Because I think every time you move from your country you also need to get a new build to make sure some interference wasn't "saved". But how to be sure that the equipment you get isn't faulty either? Maybe the only solution is to build your own computer in a very good environment.
I know I must have some sort of perception syndrome or something, causing enemies on the screen appear more distant than in reality which makes me miss all my shots and be low rank. Or there is something bigger at play that is causing it. Like developers, or other entities rigging the game against everyone affected.
They don't want to lose the player count, so if you fail at your KD the game will register more hits from you. Disappointed players will leave. Happy players can be a source of income.
Multiple times I stomped everyone, multiple times I got stomped. It's very shady if you ask me. Then they spread their propaganda that there is something other at fault, and you need to spend MORE money to fix it. Like multiple businesses working together, all in one web hugging eachother.
They probably introduced some sort of state of the art system that is hidden from the public eye and any leak of their classified money scheme is instantly welcomed with assassination. Then they hire custom made eSports "talents" to delve deeper with sponsorships and whatnot, getting more and more money in the proccess and making the printing machine bigger and more advanced. Making them an object of worship in the proccess and generating popularity and more players.
I also forgot to take my meds so take this with a grain of salt.
from my experience, pcs doesn't store the interferece in any aspect, but laptops actually does store the input lag symptom, not the floaty mouse behaviour tho
I've tested playing on the same pc in a gaming cafe with 2 different people that doesn't have this problem, they touch the pc and its all good, no problems at all, but when I touch the same pc, all the symphtoms are there, no difference between any other pc I tried, they touch the pc again, its all perfect instantly, none of the symphtoms happens with anyone besides me, when tryiing the same pc
however, laptops for some reason behaves differently, if I touch the laptop once, other people can feel the huge input lag, I've tested this with 2 different laptops and 2 different friends, the game that we play (osu) was running perfectly on both laptops, and its a pretty light game so laptops are no problem when playing this game. both of them could feel and not just only feel but we actually have the data about how worse they were playing because of the input lag, by seeing their scores
so basically pcs doesn't store the interference but laptops can do that, you don't need to change pc everytime for testing on a new place
although I tried more than 20 different pcs, on about 10 different places, 4 different cities with different power companies etc, and the problem was there at literally all those places and all those pcs
not just me but some other people reported the same, that they did the same test as I did and had the same result, they touch the pc and its bad, but when other person who doesn't have the problem touches the pc, the problem disappear
you can disconsider that option of being gaming companies or even internet companies doing that because, most of the people, if not all of them, have this problem offline, that you can feel even by moving your mouse on the desktop, also many people tried using friends accounts with no success
if you think you have something psychological or perception problems, you can think about the symptoms of this issue, and how so much people could have all those werid and specific symptoms without even know that it was a thing, for example the problem getting better after 2 or 3AM, or getting better at random days, having results by messing up with electrical things etc
one more thing is that, although I know it is the body 100%, I also do think that this problem is electricity related but instead of thinking the source is something in the external, I think our body interacts with the electricity inside the device. I think that because every laptop I tried so far, it was considerable better than every pc I tried so far, even if the pc have way better specs, the laptops still performs better in every aspect for me, laptops have less electricity running through it because it uses less watts, so maybe because of that the interferece is lower, I couldn't find any other explanation besides that, thats why I think it might be the case
Yiu have pretty much statistical data. Why don't tell this to youtubers, such as hardware unboxed or LTT etc
all the data that I have which can be used as a proof for this body interference problem, are mostly gameplay videos and screenshots of the game I play (osu), although this can be 100% proved by those data, for people to really understand and be sure of what is going on, it would be needed to those people to actually understand how the game works, understand the circumstances and the context of both the tests and the symptoms, + they would probably have to search for the actual game statistics that I mention when explaining the problem to confirm that I'm not lying or exaggerating on those, like for example, when I say "I'm the worst player in my country in some aspects of the game" or when I say "this kind of gameplay just doesn't exist in this game even if you are laggy", people just don't believe that, so they would need to search and see with their own eyes, which can be done with every aspect that I bring up when explaining
I can guarantee that any people who are really interested in understanding the problem, if they see all the proof that I have and do their own research, they cannot say that the problem is another thing but the body causing interference. even if they don't believe it because "there's no scientific proof about that", they won't have any argument against it, because after all those years, with the tests I did, it was possible to rule out every other possibility, including perception, psychological issues or me just being bad at the game
but like I said, it would need some "effort" from the people that are trying to understand that, as they would have to watch a lot of videos of gameplay, some of them having 20 minutes, understanding how the game works, reading a lot of texts explaining how I did the tests, researching the statistics to confirm I'm not lying etc, and let's be honest, people just won't do that, only a few people would be interested enough to try to understand this, and it would be those who already consider body being the issue
the idea of making a video explaining everything could work really well, if well-made, of course. it would be like a 1 hour video tho, but that's not what I'm aiming for, since I think there are other ways to prove this without being a 1 hour video with a lot of osu gameplays and screenshots. I would have to make that video by myself tho, because trying to tell a big youtuber like you said is not even a possibility in my opinion. imagine a random person coming out of nowhere talking about body interference, sending osu gameplay videos and screenshots. even people with the same problem as us don't give that much attention to this, so I don't think any people outside this rabbit hole would care about these things, unless it's something really clear and easy for people to understand
and that is what I'm trying to do right now, as I have tried everything to fix and nothing works, I want to at least make a video that can prove the body interference without having to be a gameplay video, a short and clear video so people could understand easily and have no doubts about that. I have not found a way to do it so far, but I'm trying to
amorou
Post by amorou » 01 Sep 2024, 15:25
dervu wrote: ↑
15 Feb 2024, 06:14
Lagsadok wrote: ↑
14 Feb 2024, 20:53
ApexLeg wrote: ↑
14 Feb 2024, 09:39
Try grounding/earthing.
30 minutes ago I tried playing with my PC outside it felt perfect except it started overheating cause it was in the direct sunlight lol. Played about 15 minutes of deathmatch and it felt perfect the whole time. If anyone else is in a position they can try it to test please do, obviously if you're in an apartment it probably isn't possible. I will try a grounding or earthing mat as I saw it lowers the bodies voltage to 0.
https://youtu.be/-E1odKF3Oc4?si=0hAhkgxGXmbR9GdN&t=600
They should have tested putting jenerator further away too
amorou
Post by amorou » 05 May 2025, 12:45
Allright if it is the body:
Some small infections might not show up in bloodwork for various reasons.
Living "a while" with an small infection will:
-Reduce your quality of sleep
-Make you tired af
-Mess up your immune system , so allergies might developped
I think n1 cause of undetected infections are root canals not done properly.
They are not failed ones just in between.
There will be no pain , mri scans might not show tiny lesions vs.
So here a purpose
HinetaChinoga
Post by HinetaChinoga » 19 Jun 2025, 05:25
I have had the same lags too for years, even on 20 different PC it always happen. i will use their set up fully not even my accounts, all their gear it will come back in 1 hour. at least get 1 hour of good gameplay. Hopefully people realise soon it is them causing the issue and can find a solution i have tried many things and cant fix it
Post by Slender » 20 Jun 2025, 22:45
HinetaChinoga wrote: ↑
19 Jun 2025, 05:25
that is not your body.
in an environment where everything is not working as it should, your body is charged from the air, you become a conductor of the electric field. You cannot influence the PC with your own body, but your body can collect charge and transfer it to the PC.
astroasis
Post by astroasis » 25 Jul 2025, 18:15
I had to make an account for this, this was cursing me since 2018, since then i moved out of my abusive fathers home which caused me severe emotional/physical/mental distress, the desync issue (with bad looking 1440p, sound etc) followed me until recently, i started working on making my mind and soul calmer and less anxiety ridden and less fearful of the world and people, the issue is starting to subside. Our minds have an influence on our reality, ill see if the problem comes back
100% the body/mind
Bear515
Post by Bear515 » 29 Jul 2025, 21:38
astroasis wrote: ↑
25 Jul 2025, 18:15
100% the body/mind
What a wierd coincidence my father was also abusive alcoholic and that this problem started when me and my mom and sister moved to a different place. He didn't hit us or anything and he treats us great now when we visit but the POS still lives in our big, nice house next to the lake and my mom doesn't want to kick him out because she fears he might do something to us so we just move all the time. We moved across 15-16 apartments and houses at this point and had this problem follow me all around the world since 2011. I'm convinced it is either our bodies causing this or this is some sort of MKULTRA experiment. Anyways... the problem will come back. Your mind can't alter this problem sadly.
Post by Slender » 01 Aug 2025, 14:28
astroasis wrote: ↑
25 Jul 2025, 18:15
100% the body/mind
Have you used psychedelics?
Post by Chief Blur Buster » 07 Aug 2025, 12:44
astroasis wrote: ↑
25 Jul 2025, 18:15
100% the body/mind
It can be. Some nuances are needed, because readers may misunderstand/misinterpret, so I want to nuance:
Correct: "It was 100% mind/body for me"
Correct: "Yes and no."
Correct: "It can be, but not always"
Correct: "There are many causes, computer-related and human-phsychologicals, that can create issues with latency perception"
Wrong: "Yes it is for everyone" (incorrect)
Wrong: "It never is" (incorrect)
Alas, right now, this forum is not designed to cover this type of topic, as personal as it is.
It treads into territory that this specific tech forum -- alas -- is not equipped to cover. I do humbly apologize in advance, since mental/trauma topics are not laughing matter and should not be reprimanded, so please consider this a purely "techical thread close because of scope". I'm going to manually ask the Moderator Bot (that all moderators here have access to) to post a friendly help page.
Moderation Bot
VIP Member
Post by Moderation Bot » 07 Aug 2025, 12:49
Moderator Entered Following Information During Thread Close
Reason: Our forums are not designed to cover mental/pyschological topics. We focus more on display sciences, and about hardware/software that affects displays. An addendum is attached below for those who may need the information.
Hello Fellow Community,
We recognize that this thread has moved into deeply personal territory involving mental health and past trauma. While we truly empathize and appreciate your openness, this forum isn’t designed or moderated to safely support discussions of this nature.
Sometimes some of us have hard times. Even ourselves too, at varying different (less/worse) difficulities, at different times in lives. And we certainly can see that there may have been worse times than we can imagine. We understand.
Out of respect for your well-being β€” and to keep the forum focused on its intended subject β€” we’re closing this thread. If you're feeling overwhelmed or need someone to talk to, we strongly encourage connecting with a licensed counselor or mental health professional.
For confidential support and guidance, here are some helpful resources:
Canada: Wellness Together Canada β€” https://www.wellnesstogether.ca
USA: Mental Health America β€” https://www.mhanational.org
UK: Mind β€” https://www.mind.org.uk
International: https://findahelpline.com
Thank you for understanding. We care about our community and want everyone to get the right kind of support when needed.
Take care,
β€” The Admin Team
Locked
