[Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues [Closed/Not Relevant]
- Slender
Re: [Bad LOD in Games | Juddering PC] Management Engine(Locked/Damaged) - Enhanced i/o issues
A usb key purchased directly from ms is no different from the version they distribute through MCT. This has nothing to do with reality. I watched a laptop running on exactly the same custom windows build that my PC is running on, the difference was obvious. The laptop didn't even have a license key and was hacked via KMS. The only difference was that the power was from the battery, as soon as I connected this laptop to the LAN or socet, I immediately felt the same as on my PC.
I still can't figure out what your theory is based on. Is the explorer tearing in safe mode? This is because DWM cannot use VSYNC (because it is supplied by drivers). I still don't see any convincing EVIDENCE that would indicate that the input delay problems were caused by damage to the insides of the PC. I'm talking about those proofs (not the temperature on pch), that could confirm this for sure - but they are not there.
- Z3CrosS
There is a difference between Genuine Windows Retail and MCT, you have just to look better.
All high speed lanes are PCIE lanes, ethernet controller is one of them, just depends of wifi / lan controller(physical driver) realisation.
"Is the explorer tearing in safe mode? This is because DWM cannot use VSYNC (because it is supplied by drivers). - Not, it is not.
Hint: if you look in Nvidia drivers installation log you will see errors in it
I think that i don't think
texre
i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
- Slender
really thanks for info.texre wrote: ↑28 Sep 2024, 13:28i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
when you change your provider, do you change your lan/provider cable?
texre
yes i went from fiber to cable and its 1000 times better i can actually play games again at my skill level.Slender wrote: ↑03 Oct 2024, 17:05really thanks for info.texre wrote: ↑28 Sep 2024, 13:28i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
- themagic
texre wrote: ↑04 Oct 2024, 20:29yes i went from fiber to cable and its 1000 times better i can actually play games again at my skill level.Slender wrote: ↑03 Oct 2024, 17:05really thanks for info.texre wrote: ↑28 Sep 2024, 13:28i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
What exactly Cable provider you have now ? Where you from ?
And your ping latency become higher on Servers u usually play or it is still same like it was on fiber ?
You tried to go deeper and figure out why fiber was worse for you and what rly was the reason behind this ?
- dervu
When I went from fiber to cable it was total shit, could not even shot anyone.
texre
im from California WHICH is the reason why i stopped believing it was power. but i had frontior fios 1000 up 1000 down switched to spectrum cable 400 uo 10 downthemagic wrote: ↑05 Oct 2024, 06:28texre wrote: ↑04 Oct 2024, 20:29yes i went from fiber to cable and its 1000 times better i can actually play games again at my skill level.Slender wrote: ↑03 Oct 2024, 17:05really thanks for info.texre wrote: ↑28 Sep 2024, 13:28i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
when i see my internet graphs on the fiber it just doesn't look normal even tho all tests come back fine. i think it has something to do with the way they set up the lines to my house but i have a new fiber company coming in a few months and ill be tying them out too see if thats better then my cable internet. but as now everything runs smoothly no more weird deaths or wondering what happened, i can play normally after years. if my issue does come back ill be back in the forums again but ill keep you guys updated
- Slender
Tell me, besides the cable and the PC, did you change other equipment? The router? How was the optical cable connected? An optical cable came into your apartment, then it went to the router, and from the router the same optical cable or RJ45? How new setup is connected? Just provider rj45 to router and same rj45 to pc? If you changed equipment, tell me which router was old and which is new. What is new/old RJ45 cable? That is shielded sftp or standard?texre wrote: ↑04 Oct 2024, 20:29yes i went from fiber to cable and its 1000 times better i can actually play games again at my skill level.Slender wrote: ↑03 Oct 2024, 17:05really thanks for info.texre wrote: ↑28 Sep 2024, 13:28i think my issue is finally gone i changed internet providers and it was night and day i did this about a month ago. so idk about getting all new parts and geniune windows key. ill probably never be back on here again unless it comes back but i doubt it. good luck slender im praying for you.
SKILLEN
Also went from fiber(150/150) to cable(75/30) yesterday .My ping is higher , i got regular 0-3% loss,with fiber loss is 0% .
Still when some action is happening or when i shoot enemy my mouse becomes floaty(heavy ,delayed),but its a little bit easier to kill. I took a pic of my last 20 games average statistic and i think they will go up.
I think its the provider in my case and not the cable vs fiber ,but i dont know.
I don't understand why there is any difference at all between ISPs
Rj45 to house to router(same router) and Rj45(same cables,tried few cat8 ,cat5e) to PC.
Tried Rj45 directly to PC ,its the same.
