After all these years and still no fix for this input lag and desync :(
unexpected8
Re: After all these years and still no fix for this input lag and desync :(
Post by unexpected8 » 26 Aug 2026, 05:26
I tried it without soil, but it didn't improve. The improvement was only with soil. Secondly, I have proper grounding at the electrical outlets, so don't worry, but it has a high resistance.
As for the soil outside, I planted a rod approximately 1.70 meters deep and it didn't give me any improvement.
MaleGigolo
Post by MaleGigolo » 26 Aug 2026, 11:57
MontyTheAverage wrote:
25 Aug 2026, 23:54
MaleGigolo wrote:
25 Aug 2026, 10:43
Hubcio wrote:
25 Aug 2026, 09:34
MK92 wrote:
25 Aug 2026, 03:25
You people are in big minority, many many people actually did fix it by moving / fixing electrical installation (including myself), they just don't report it on forums anymore after they fixed their issues...if you moved 20 times, tried 20 different PCs, then I'm sorry but you have some other problems, maybe in your brain...and no, it is MUCH more ridicilous thinkin that your body is causing computer lag and error-correction delays inside a sealed faraday cage (pc case), meanwhile it is scientifically proven that ripple, voltage drift, harmonics etc. are causing erratic PC behaviour because of wobbling and unstable 12V rails.
I agree with you, there is no way body is causing input lag or desync. It’s crazy theory, too crazy- and it’s pretty dangerous imo to believe in shit like that
Did you even read what i said? I said this problem is an anomaly never claimed i was 100% certain it is body. It is dangerous to believe that messing with electricity will solve this problem. I will say this again: I did an actual test with Steam Deck and a DIY faraday cage and the problem was still there. I made sure to charge my Steam Deck using Anker charger and charged it my car because i believed "dirty power" bs claim. Tested games in a tunnel as well. I made sure to install Windows to prevent Wayland input lag on SteamOS and have as much input lag free experience as possible when i did the test. Played some games and had massive input lag. It did nothing. Believe whatever you want now.
I had same experience. Problem same across games, locations in 3 continents and several countries, several different PCs, different isps, even in gaming cafes, on laptops/desktops/consoles, online/offline, running on battery/running on solar or trying on powerstation. It's an anomaly that I don't know what it is. And same with sometimes getting fixed for a bit from random BS tweaks.
I will have a game where I go 50/10 KD without even trying in BF6 after some random tweak I hear about once in a while and that same random tweak will not work again until weeks later possibly. Sometimes it improves randomly for a bit without doing anything also. Enemies play like bots / move and react slower even good players on the other team. Rest of the time when the lag issues are not good, I either go 20-15 after trying hard or negative K/D where enemies react instantly and dying in a second, enemies seme to move faster and feels like it takes more bullets to kill the same players. And this all can happen in the same match, where I start out with minimal issues where my K/D is 15-2 after 5 minutes of playing and by the end of the match My K/D is like 22-20 as the lag issues get gradually worse over the same match.
And usually first game of the day is good and after progressively get worse with more and more input lag/delay, inconsistent mouse, desync, behind the server feel, hitreg issues, muffled sounds, graphics/refresh rate not feeling and looking right, broken aliasing/jagged edges. unsmooth screen and 165 hz feeling like 30 hz. But, I will try few more locations and gaming cafes to confirm my experience so far more.
Every time you make a change to Windows or your PC there is a massive, complex chain of things happening in the background that you are not aware of and some of those things can directly influence the response time of your system. If you change something random on your PC, like disabling HPET for example, you can trigger a chain reaction and it can take time for your PC to return to its normal baseline. The thing is for for people who don't have input lag issues their baseline is already normal so they don't notice such drastic changes but for people who have input lag our baseline is much lower and our latency/input lag is already high so when it stops working we notice it come back in real time. By doing random tweaks you are never solving this mysterious input lag you are just artifically lowering response time of your PC by messing with random settings and getting a random reaction. This is why you can disable HPET today or mess around with Windows services/BIOS settings and have a pretty solid gameplay but comes tomorrow and you try that again and it no longer works. It's never consistent because it is completely random and depends on random explosion of events that happens inside of your OS/PC. Guys like r0ach and other tweakers are correct that their tweaks are not placeboo but they refuse to adress that they have this massive source of input lag , like we do, that is making them do all these crazy tweaks IN THE FIRST PLACE because let's be honest... if you are someone with a properly working PC you wouldn't be chasing unicorns and trying to reduce your system latency by 0,001ms instead, you would simply enjoy video games.
TL;DR: Those random tweaks work but they are only temporary and do not help with our main source of problem/input lag. It's like polishing a turd. You might reduce overall input latency of your PC but the main problem is still there you just don't notice is because your system is artifically working faster for a short period.
astroasis
Post by astroasis » 26 Aug 2026, 13:20
Also the online UPS on battery test is also pointless and doesnt prove anything, because the same fake effect as changing a setting or wiggling a wire might be at play, and itd lose charge before you can play long enough
SweatHatesMe?
Post by SweatHatesMe? » Yesterday, 17:39
themagic wrote:
19 Nov 2024, 08:21
simon wrote:
18 Nov 2024, 07:26
Glad we're on the same page. This topic would gain so much more traction if people could see past themselves. What I mean by this is when their game is desynced and not running right then it's not them, it's a million things wrong - okay, fair enough. But when the game is running smoothly and they're pwning, then it's their skill and the game should be like that. But what if it's the same phenomenon that either allows you to make kills and be unhittable and fast while your enemies stand no chance, or it makes you an easy target for the enemies with the desync and all that stuff. Once you see this not only for yourself but for others too when they can't get any kills and you're having a blast then it changes how you see every fps game. There are some back and forth really balanced rounds that seem to be normal/neutral but it appears to me there's always some advantage factor other than skill.
Once you get this far with your thought process then you will wonder how much does skill really matter? How much does expensive gaming equipment really matter? I'm not saying either makes no difference but there is a line where the game itself starts limiting your abilities for some reason.
Just looking for the truth and I really can't find much discussion about it that is legit truth seeking, not someone trying to sell you something for attention.
Look at Call of Duty and what happens there...I stopped playing this game long ago but the experience some players describe is same what i experience in games like CS2, Valorant and started with Black Squad some years ago here and even in Rocket League i noticed that something happens with my Car and i'm unable to control it like before in the matches or the FIFA thing where players feel that for some reason the Players running slow on the Field and like there is huge latency and input lag and you start losing cause of that shit and getting goal by goal scored on your side and you just can't do nothing against that shit and you start to feel that things are completely unfair on your side from that point on...
Nah fuck this all shit but i already saw everything and i know for sure now that Developers doing there dirty things too and are to blame too and it's not only about providers and servers quality and ping shit talk differences...
Call of duty is the best proof for all the shit is going on today but it's sad that many Players just accept all the shit and don't react or even keep defend all this System and how things going on and they keep call that Esports and Fairplay...that is just the most disturbing thing about that all and the Online Gaming today at all.
If that is what Esports is...then we lost and it can be rigged and depends on luck and location where you living. And by this chance you have more LUCK to win in Lotto than to become an Pro Player who gonna earn some Money with that today or some day...
And that is the most fucked up Thing today and everything...some gonna understand and others will give a fuck and call me as an delusional and retarded but i don't give a fuck more. But i can imagine how things are fucked up in this World and everything that happens today just proofs and proofs more that i am not the Crazy one...But this World is and many many People who agree and keep support such things and act like everything Fair and Fun and Skill about. :!:
Heyyy, I also play rocket league! Apart from hard car control, have you also experienced “weird” physics bc of the input lag or as if every 50/50 is rigged on side of the opponent?
