⚡Intel/AMD Fix desync, input lag, heavy car bug, etc *FINAL UPDATE*⚡
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
Z3CrosS
Re: ⚡Intel/AMD Fix desync, input lag, heavy car bug, etc *FINAL UPDATE*⚡
Post by Z3CrosS » 09 Jan 2025, 16:16
I think that i don't think
naporitan
Post by naporitan » 09 Jan 2025, 21:58
Updated some information.
Z3CrosS
Post by Z3CrosS » 10 Jan 2025, 05:05
naporitan
Post by naporitan » 12 Jan 2025, 01:33
Answer for the sectarian Extreme Low DPC latency its GOOD for gaming.
viewtopic.php?f=10&t=14187#p111532
naporitan
Post by naporitan » 13 Jan 2025, 00:32
vroktylF
Post by vroktylF » 20 Jan 2025, 05:07
If you want to be able to use Directstorage don't install manufacturers NVME driver.
DirectStorage requires an NVMe SSD to store and run games that use the Standard NVM Express Controller driver and a DirectX12 GPU with Shader Model 6.0 support.
naporitan
Post by naporitan » 21 Jan 2025, 22:48
vroktylF wrote:
20 Jan 2025, 05:07
It's true.
naporitan
Post by naporitan » 21 Jan 2025, 22:54
Important information!
Some systems may not work correctly due to drivers from the official website of the motherboard!
symptoms: processor not reaching the stated frequency, ignoring bios settings and other various problems.
fix: clean install windows, update the system through windows settings and also set “optional drivers” in update settings.
example of a correct system:
The update log should show the status of update installations as successful, and if there are errors, here is a recommendation for fixing them: Disable windows update service and go to C:Windows\SoftwareDistribution and delete everything inside that folder and run update check again.
:!: @Z3CrosS is not telling ghost stories, but a real problem that can occur for various reasons and other/chipset drivers are one of them.
Post by Slender » 22 Jan 2025, 10:06
and don't forget to update gamebar
naporitan
Post by naporitan » 22 Jan 2025, 10:51
