Re: 240hz displays are blurry
Posted: 27 Dec 2017, 22:46
Easy, easy, please.
Be nice to each other. Forum rules. Thanks.
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
BenQ 240hz:Acer Predator XB252Q is really blurry and sh***y
BenQ 240hz:The BenQ Zowie XL2540 was met with decent reviews but worries about motion trails (overshooting pixels that create a blurry visual) made us look at different monitors.
Asus 240hz:Also compared to the xl2450, everything is a lot more visible to my eyes when moving, it doesn't seem to have the extreme fuzziness/blurriness I was experiencing on the zowie.
Acer 240hz:During fast movements with PG258Q, it feels more like "smooth motion blur". Objects in the game lose their contrast around their edges and sharpness during a fast "swipe" and everything becomes more "blurry". Therefore I recommend ULMB on PG258Q for games where the fps is constantly very high (like csgo). It is possible that the PG258Q feels more blurry due to the higher refresh rate and limitations with your eye? Perhaps this is because the higher refresh rate requires a better overdrive / AMA to have the same contract / sharpen as shields with lower refresh rate?
I do not know why it feels better on the XL2411t with overdrive, but it is noticeable that it affects the flicks in play. An easy way for me to see the difference is when I run both screens in mirroring, and just spin the mouse pointer in Windows. The PG258Q mouse pointer can actually be "dropped" due to the higher motion blur, while the XL2411T makes it easier to keep track of the mouse pointer, as it is clear even during motion.
Comparing 1080p 240hz gsync to dell 1440p 24 inch gsync i choose the sharpness of 1440p 165hz over 1080p 240hz. Also the acer seemed to have ghosting or blur at 240hz but the dell being lower hz still looked clearer. I will miss the lower input lag though but thats about it.
If you read my original post, I stated I did an A/B test side by side with a 144hz display and the 240hz display and set both to 144hz with the tesfuo site. I don't think the test drops many frames once it hits the green valid, but both displays had G-Sync on. I originally stated I observed the Alienware looked much blurrier:open wrote:When you increase refresh rate, it can make still eye observations see the effect of pixel response times more.
When you increse the sample and hold time, (like you would when your fps dips on a gsync monitor) it can make moving eye observations see more motion blur.
So even though the 240hz gsync monitors have the best yet pixel response and lowest sample and hold times:
-There are times when the fast refresh rate can empasize the pixel response bluring. You might not be able to notice it at a lower refresh rate.
-There are also times when gsync fps dips can make eye tracking motion blur varry. Because the fps changes the sample and hold times and the sample and hold times determine eye tracking motion blur.
This is normal and you will still have the best pixel response and best potential sample and hold time on the 240hz.
If you are not noticeing what I am talking about then there is something wrong with your monitor and that is not normal for a 240hz. Best to speak clearly and not get the two things confused with eachother. If there is a problem then there is a problem. If we are talking about the subtle variations in motion blur depending on certain conditions then that is something else and is just part of the tech of modern lcd's that is getting better with each iteration.
So I think that test helps rule the higher refresh rate, fps, or g-sync being the culprit. I also played with the Alienware with G-Sync off and didn't notice a difference.I do a comparison, I set my AOC to 144hz vs Alienware at 144hz on the testufo site using the alien invasion test. I stretch the browser window across both screen, and sure enough, the Alienware looks incredibly blurry or fuzzy in comparison. Even if I downscale the AOC 1440p resolution down to 1080p, the Alienware still looks incredibly blurry in comparison. I don't know if it's the pixel overdrive, the coating, or what - but it's terrible when you see it side by side.
In a way, this is correct:open wrote:When you increase refresh rate, it can make still eye observations see the effect of pixel response times more.
Or more ghosting. GtG response time with variable frame lengths means that ghosting can become more visible at specific frame durations (e.g. specific refresh rates). E.g. The overdrive may not be perfectly calibrated at a specific refresh rate like 173Hz or 159Hz or whatever you will -- for it to be perfect, the VRR's variable overdrive (Which must dynamically vary properly) to tune GtG in a custom way to minimize ghosting/corona artifacts during all frame duration times (all Hz in the VRR range).open wrote:When you increse the sample and hold time, (like you would when your fps dips on a gsync monitor) it can make moving eye observations see more motion blur.
Yes, but that doesn't necessarily mean they do 144fps (during 240Hz G-SYNC) as clearly as a native true 144fps @ 144Hz non-GSYNC monitor. The degradation may be tiny, like 1% or 5% worse ghosting. Many of us do not notice, but it's often there -- and some humans are just remarkably sensitive to asymmetries in the linear motion blur (aka ghosting, coronas, etc).open wrote:So even though the 240hz gsync monitors have the best yet pixel response and lowest sample and hold times:
Agreed, that's normal, too. In an ideal monitor, 144Hz or 144fps on a 240Hz monitor should look as good as 144fps@144Hz -- assuming darn near perfect overdrive creating the best possible symmetry in motion blur (and no discolorations).open wrote:-There are times when the fast refresh rate can empasize the pixel response bluring. You might not be able to notice it at a lower refresh rate.
Whoa, hold on. What one human notices, another doesn't. Not everyone is flicker sensitive. Not everyone is stutter sensitive. Not everyone is tearing sensitive. Not everone notices 3:2 pulldown. Same thing. Not everyone instantly sees motion blur asymmetries (ghosting/coronas).open wrote: If you are not noticeing what I am talking about then there is something wrong with your monitor and that is not normal for a 240hz.
Correct, it's important to speak clearly. Alas, when it comes to such subtleties like this, it gets horrendously difficult to speak clearly about it.open wrote:Best to speak clearly and not get the two things confused with eachother. If there is a problem then there is a problem.
There is no verdict, just opinions, unless someone who has proper testing methodology can give comparison results. Some say no issue, some say issues, some say bad panels and have to be swapped, etc. But for me, I think the ghosting test ufo images from review sources speak for themselves and matchup with my experience.BTRY B 529th FA BN wrote:TL:DR
So what was the verdict? Was something not configured right? Was it hardware? Considering one myself,
Thanks!
If you're thinking about spending $500 on a monitor, the least you can do is spend 15-20 minutes reading through this and making your own decision. In that post, I link to 2 other posts, I use sourced images from reviews that test ghosting to draw my conclusions. If you can follow along and see the flaws I point out, chances are you won't enjoy 240hz. If you still want to buy one, I suggest you order from a place that has a good return policy, so you won't have to pay $40 to send it back.Overdrive for 240Hz monitors are still in its infancy and calibrations for 145fps-240fps frame rates cannot recycle 144Hz overdrive lookup tables (but many probably did it) without making certain kinds of ghosting artifacts reappear.
"your own decision" after recommending someone to read some cherry picked bad things about the product.If you're thinking about spending $500 on a monitor, the least you can do is spend 15-20 minutes reading through this and making your own decision.
