Found the best gaming monitor by accident
sempronius
Re: Found the best gaming monitor by accident
I do not need to prove anything. I just reported my personal experience with extended and repeatedly playing the same game.
Read carefully:
I did not write "that the 240R *is* <...> faster", but that I *found* it faster.
So it is my personal impression, and I marked it as that.
For me, there is no doubt about this ranking because I am very sensitive to subtle differences in game responsiveness. Of course, other people might have a different experience.
But it could also be that my results were due to the variability of individual units of monitors - *but the same could be said about public reviews!*
Often my own experience is different from the results published by reviewers (like rtings, pcmonitors.info). So such reviews - whilst very useful - can still be misleading and get people to buy monitors that have been praised by reviewers and might be based upon best quality samples that are better than the monitors people can purchase in the end...
Anyway, I am not here to offer a scientific result - I just commented about my own experience.
Read carefully:
sempronius
By the way, that the Viewsonic XG240R has less input lag than the Acer XN253QX is not only my personal impression, it is also what pcmonitors.info "confirms" (though I am always skeptical of pure test results, but still...):
input lag of 2.86 ms for XG240R
input lag of 3.26 ms for XN253QX
both values very good after all!
sempronius
Did someone enter the service menu of XN253QX? Has it been confirmed that it uses panel version 1.9?
Currently, I have an XN253QP here, I had a look in the service menu, it shows version 1.6.
So do the QX versions always come with the newer panel?
SilverOne
Geizals and other websites seem to list the panel as the new one. Either way if you look up reviews the pixel response is at another level. I dont think there are any doubts these are the new panels.sempronius wrote: ↑24 Dec 2019, 19:31Did someone enter the service menu of XN253QX? Has it been confirmed that it uses panel version 1.9?
sempronius
As I said, I have the Acer XN253QP here right now (still time to send it back).
Would the Acer XF252Q be worth buying instead? Most likely, I won't keep the XN253QP - and the reason is the horrible stand which takes too much space and is unstable because the back part of this "foot" is also curved; so pushing it back to the border of the table is risky because once it crosses that border it easily tilts and drops to the ground. I do not like this shape of monitor stands. The Acer XF252Q has a "normal" stand.
BlurBoss
I agree, the stand is not good. I recommend getting adjustable monitor arm with VESA - it's much better experience. I'm using Arctic Z1 3D Gen 1 on my BenQ XL2456, but unfortunately it doesn't fit XN253Q P, square for VESA on Acer is a bit smaller. The arm would fit if I'd cut the metal away though.
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
Mr___Love
I'm new to finding out about ULMB, I play a ton of Halo and Rocket League. Can you link me anything that would show a noob like me how to set up ULMB with the correct settings etc. I will be exchanging my monitor for the XN253QX.BlurBoss wrote: ↑14 Oct 2019, 16:48jombotski, so I've spent 5 days with Lenovo Y27gq-25 and 1440p on it is amazing! I'm going to miss it but will stick with XN253QP anyway, for better motion clarity as 120 Hz + ULMB on it is gives less blur than Lenovo Y27gq-25 at 240 Hz.
Tenobaal, can you give me a link about that update that switched TAA Antialiasing to enabled in Rainbow Six Siege?
antiblur
Hi. I am having the same problem. I did not understand your recommendation a little, because I speak Russlan and know English poorly (I use a translator). What do you recommend to solve this problem? Store the monitor with the display up for a couple of days? Or turn to portrait mode? Thx/Chief Blur Buster wrote: ↑03 Dec 2019, 16:59LCD pressure spots from rear mount. Keep monitor on 24 hour and vertical for one or two days, and see if that fades. This sometimes happens when the monitor is stored/shipped flat (not right side up) or the back is assembled too tight. If it doesn't disappear, then this is bad enough for RMA.
viewtopic.php?f=13&t=9371&p=74885#p74885
monitors: TN ACER 1916 (75Hz)>TN ACER 1917 (75Hz)>XL2540K (240Hz)>IIYAMA MASTER VISION PRO 451 (CRT 160 Hz)>xl2546k>omen x 25>24g2zu>xv252qf
LCD stands for "Liquid Crystal Display".antiblur wrote: ↑23 Nov 2021, 23:23Hi. I am having the same problem. I did not understand your recommendation a little, because I speak Russlan and know English poorly (I use a translator). What do you recommend to solve this problem? Store the monitor with the display up for a couple of days? Or turn to portrait mode? Thx/
There is a liquid between the glass layers of the display.
PROBLEM:
The monitor stand can create pressure spots if your monitor is stored.
A monitor that is tightly packed in a box.
Or the monitor box is stored improperly, or the box is shipped flat sideways on the shipping courier truck.
The weight of the stand is pushing on the glass. Like a big finger pushing on a screen. The screen distorts with pressure.
SOLUTION:
Run your monitor for at least 72 hours at maximum brightness.
Turn off your screen saver.
The liquid will flow around, and then balance more uniformly.
The bracket pressure spot will disappear.
Blacks and grays begin to look better.
If still not fixed, then claim the warranty.
I made my sentences simpler for easier translation.
I have tested this in Google Translate in English, then Russlan, then English.
It remains readable. Hopefully you understand better.
antiblur
TY! Do I have to place it with the display facing up during this procedure? Would it be better if a color video or black and white video was launched during this procedure?Chief Blur Buster wrote: ↑23 Nov 2021, 23:37
