HUGE Fix at Input Lag!!!!
forii
Re: HUGE Fix at Input Lag!!!!
Post by forii » 09 Feb 2021, 11:39
secretiveolwagner wrote:
08 Feb 2021, 22:05
forii wrote:
08 Feb 2021, 00:15
Well Im on 460.89 nv driver, win 10 2009 ver 19042.746 + rtx 3080 and this works for me:
This is weird, I have a RTX 3090, I get the exact options like you have in the screenshot on Windows 7 but not on Windows 10 20H2, Which nvidia inspector are you using?
2.3.0.12 from this thread.
But tbh just scroll down :D and you will find exactly what I have :twisted: :twisted:
forii
Post by forii » 09 Feb 2021, 21:01
IF I would like to run g-sync only (no-vsync) then I only need to turn on (0x1) the g-sync values on this screenshot?
what about vertical sync?
pox02
Post by pox02 » 09 Feb 2021, 21:43
forii wrote:
05 Feb 2021, 13:39
pox02 wrote:
15 Nov 2020, 20:42
if u want really low input lag for overwatch try my settings :)
why set refresh rate to ff0? its hidden feature that nvidia missing its called low-Latency REFRESH_RATE_OVERRIDE_LOW_LATENCY_RR_MASK
u can check here https://docs.nvidia.com/gameworks/conte ... gs_8h.html
DISALLOWED is the lowest input lag flip is good to but if u want hit ur shots over smoothing try it
now the real settings that give u snappy mouse movement
MAX_PENDING_CMD_BUFFERS to 0x1 remove the stutters/lag
MCFORCEHOSTSTAGINGBUFFERSIZE this is really fun u can check it over 1000 but recommending not go above 20 set it 0x00000001 for extreme mouse input lagless
enjoy the fastest mouse input in ow :)
one more thing i forgot to say to u make sure low latency is off cause disallowed work best with off
And how does it work with Nvidia Reflex Time? (ENABLED + Boost In call of duty game settings) - Should we also keep it off like in nvcp?
I had my MCFORCEHOSTSTAGINGBUFFERSIZE to x0.000000 default so idk if I should change it
Talking here on win10 ofc
i didnt test so i dont know but try it
MCFORCEHOSTSTAGINGBUFFERSIZE change to 0x80-0x82 for consistent frames and smoothing if u want responsive try 0x1-0x4
i test gsync 360hz v3 limiter vsync on vs off :)
https://imgur.com/a/XnNeloB
0.1 lows a lot better with vsync off and v3 limiter with gsync !
forii
Post by forii » 10 Feb 2021, 12:01
pox02 wrote:
09 Feb 2021, 21:43
Thank you pox02
I keep MCFORCEHOSTSTAGINGBUFFERSIZE to 0x4 (cuz I heard lowest value is default)
I think response time is better than smoothing, but what did you mean with consistent frames?
If it comes to MAX_PENDING_CMD_BUFFERS I tried to set it to 0x1, 0x2, 0x3 but I get stutters every few or more minutes. I keep it 0x0 cuz idk what value is respectable to make my game smooth
If it comes to g-sync doesn't it add some input lag? When I play COD Warzone on my 1080p 240hz my fps are always bellow 240hz -> Do you suggest to run g-sync then? But I cant find v3 limiter inside my nvidia inspector:
Also, are there any other values you recommend? I tried your no-vsync profile but then my Nvidia filters doesnt work.
Thank you for ur time :)
pox02
Post by pox02 » 10 Feb 2021, 14:09
forii wrote:
10 Feb 2021, 12:01
pox02 wrote:
09 Feb 2021, 21:43
Thank you pox02
G_CMD_BUFFER
If it comes to MAX_PENDINS I tried to set it to 0x1, 0x2, 0x3 but I get stutters every few or more minutes. I keep it 0x0 cuz idk what value is respectable to make my game smooth
MCFORCEHOSTSTAGINGBUFFERSIZE lower can cause stutters in games thats why i suggest use high value like 0x80-0x82 to avoid those stutters and get smooth image
max_pending not work for every game some games like it some not
try gsync with vsync off and limiter v3 like this 3 fps below for gsync range
if not work try this
i found new vsync mode ??? but apparently work only on 240hz monitors ??
Code: Select all
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers\Scheduler
"ForceFlipTrueImmediateMode"=dword:00000001
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 10 Feb 2021, 22:59
forii
Post by forii » 07 Mar 2021, 19:25
pox02 wrote:
09 Feb 2021, 21:43
What do you think about something between? is it worth? like 0x20? :) Smoothness at 0x80 is nice but I think for call of duty I prefer more responsivness (hard to say? :idea:), but if I want to still keep smothness + have better responsivness what about 0x20? or 0x40? :idea:
Not using any other options in NV inspector except all g-sync off + limiter off but this MCFORCEHOSTSTAGINGBUFFERSIZE really works!
pox02
Post by pox02 » 08 Mar 2021, 16:10
forii wrote:
07 Mar 2021, 19:25
pox02 wrote:
09 Feb 2021, 21:43
try 0x10 0x20 is ok to but 0x10 is combined with extreme low lag and smoothness
forii
Post by forii » 09 Mar 2021, 07:06
pox02 wrote:
15 Nov 2020, 20:42
Can you also confirm that refresh rate is good to set for ff0 if we will use nvidia reflex? (low latency by itself)
For now I keep it as default due to nvidia reflex ( i think nvidia reflex is better than hidden features in nvidia inspector - I might be wrong tho)
Ah nvm I already noted that you didnt test it.
Anyway I can decide between smoothness vs responsivness... what would you do in Call of Duty Modern Warfare? For multiplayer I think responsivness is better but for warzone = smoothness..
forii
Post by forii » 09 Mar 2021, 14:38
Also I couldnt set framelimiter to 240 fps, I tested every option in frame limiter v3, I think what worked is just this:
is that still better than using RTSS?
