bro, you took this setting at the morning.napoliane wrote: ↑19 Sep 2024, 20:40After searching for a solution and trying a few things mentioned in this thread, I found a fix that I wanted to share.
I have an MSI B550 Carbon Gaming mobo. I loaded into the bios and enabled Re-size BAR Support. The file path for the advanced bios setting is shown in the screenshot (I think) that I attached.
From there I loaded into Apex, and everything has been smooth as always. If something changes I'll update this post.
and.. apex use resizebar? maybe above 4g give you better (not enable resize setting).
