LG 27GK750F-B - 240Hz, 27" 1ms Blur reduction, Freesync
mushi
Post by mushi » 13 Jan 2020, 07:08
keep us posted guys.
what part is it exactly? get every detail you can and share for the others please. thanks!
sat5uma
Post by sat5uma » 14 Jan 2020, 14:21
Still worth buying one? I play CS:GO competitively and I looking for a 240hz monitor, with some smoothness better then my VG248QE and I read almost all the thread, was a nice reading, learned so much!!!
Aynway, still worth? despite the firmware not updated/stutter bug? (since can be temporary fixed using CRU)
addi
Post by addi » 15 Jan 2020, 15:25
sat5uma wrote: ↑
14 Jan 2020, 14:21
To be honest, get something else...
It is really not worth it.
LG does not care at all. And now a lot of the monitors are just dying...
The customer support is a nightmare.
I'm really not happy with my monitor, i will get something else soon aswell.
Never again LG products.
sat5uma
Post by sat5uma » 16 Jan 2020, 11:53
addi wrote: ↑
15 Jan 2020, 15:25
sat5uma wrote: ↑
14 Jan 2020, 14:21
Sad to hear.
Do you know any other options? with good MBR and low input lag? I prefer TN panels and 240hz.
Unfortunately, I'm from Brazil and the options here are limited.
I saw an AOC 240hz 0.5ms MPRT and 0.5 G2G (specs informations) but TFTCentral said that they are using the new AUO TN 0.5 ms panel but theres no a single review out there.
Hadookaan
Post by Hadookaan » 21 Jan 2020, 10:19
They fixed the monitor and getting it back tomorrow, after just over one month waiting, lets see how it is when I get it! dont hold your breath guys, (didn't find out what part went wrong, probably the main board) 100% sure that in a year it will fail again, if not then I ll be very lucky tbh I ll be happy if it fails I ll get something better then! :lol: I was looking at the 48in oled when it comes out, but I dont want to get anything from LG again!
Hadookaan
Post by Hadookaan » 22 Jan 2020, 10:19
Monitor is back up and running looks like they they changed the LCD panal so maybe it wasn't the ,main board I am no expert but thats what is seems like, I was getting a stuck pixel, with the old/broke panel, which was easily to fix by gently tapping on the pixel with a soft cloth, the panel does seem new, it has a more warm tint to it ie more reddish! compared to my other screen's
Anyway let's see if it can last more than a year, or if it dies just after the warranty runs out!
Post by RealNC » 24 Jan 2020, 10:19
Hadookaan wrote: ↑
22 Jan 2020, 10:19
Story of my life :D
k2viper
Post by k2viper » 10 Feb 2020, 14:17
Wow... they dying as flies, I cant even expect this )
My one still running "fine", meaning now it's not worse when I bought it.
ghostrider94ac
Post by ghostrider94ac » 28 Mar 2020, 05:39
hi @k2viper i used your settings to fix monitor stutters, but when i use strobe crosstalk test on ufo test i experience double o even worse like triple image even on 1180/1182/1304 vt, anyone got same issues? there is a way to fix this cause strobe utility works only on benq if i remember correctly and i just have to run it on normal or freesync mode, is so frustrating cause crosstalk has a very bad impact on my aim in games where i need pin point accuracy
Auroreka7
Post by Auroreka7 » 11 Jun 2020, 22:00
FUCK
my LG 27GK750F-B just died with the white screen
called LG parts.
I was quoted for this part https://lg.encompass.com/item/11527154/LG/EBU64508601/
$229.03
They don't sell the panel, if that's the issue with the monitor. (possibly out of stock? hard to understand)
