Stevie66
Post by Stevie66 » 03 Jun 2023, 21:23
Do you think doing the 280hz OC shortens the life of this monitor? I do feel it seems a bit warmer but that's it
Though I do like 234hz OD100 the most. Never had the screen black out yet like others mentioned
joseph_from_pilsen
Post by joseph_from_pilsen » 04 Jun 2023, 06:37
For me the screen blackout happened only with:
stock Asus original fabric cable with usb-c/DP convertor
stock alienware DP cable
Stopped happening with quality club3D 8K usb-c DP cable.
Stevie66
Post by Stevie66 » 04 Jun 2023, 09:11
joseph_from_pilsen wrote:
04 Jun 2023, 06:37
Oh strange, I'm just using the stock Asus DP cable(which is just a thick rubber cable) does newer 259QM come with fabric ones with a usb-c? mine is DP to DP.
Also I'm using the settings posted here before that gives exactly 250hz if that makes any difference, I have no idea
d4rthvdr
Post by d4rthvdr » 08 Jun 2023, 04:44
hello.
let me know please. i have to play one old game (ql). there is maxfps 250. if i set the monitor to 250hz+OD120 it feels perfect. many players say that its better to use equal fps/hz. so the question is about input lag. how many it would be on 250+OD120? or still better to set 280+OD120 ?
regards
joseph_from_pilsen
Post by joseph_from_pilsen » 08 Jun 2023, 05:41
stock asus cable is trash, get an 8k or 10k better one to prevent blackouts. Doesnt matter if you use DP-DP or USB-C - DP depending on your GPU.
Stevie66
Post by Stevie66 » 08 Jun 2023, 16:56
Never had a blackout yet at 235fps 100 OD with the stock cable.
joseph_from_pilsen
Post by joseph_from_pilsen » 08 Jun 2023, 18:26
always had a blackout at 280fps with the stock cable
neo001
Post by neo001 » 08 Jun 2023, 23:12
Hi, i get one VG279QM, what is the best settings to play CS:GO?
d4rthvdr
Post by d4rthvdr » 09 Jun 2023, 12:56
axaro1 wrote:
09 May 2023, 14:54
Yes, it's definitely safe.
let me please know... i have to play one old game (ql). there is maxfps 250. if i set the monitor to 250hz+OD120 it feels perfect (many players say that its better to use equal fps/hz). so the main question is about "input lag". how many it would be - 250+OD120 or still better to set 280+OD120 ?
regards
DarkLord1337
1440x1080 res fonts in windows look bad+ingame resets to 240hz
Post by DarkLord1337 » 15 Jun 2023, 10:47
i made 280hz 1440x1080 res in cru with exact reduced timings. but ingame i think it resets to 240hz coz in osd it says 240hz and after i alt tab back to windows settings it says 240hz in display settings of windows. i tried gtf and cvt but it was out of bounds. also fonts in windows on 240hz 1440x1080 look good but on 280 they r blurry, like letter e has horizontal line with semi-transparent pixels instead of solid color like on 240hz. what timings should i use and also why valorant changes to 240hz
upd: did 240hz exact reduced on this res and in windows there was 279.857hz on which i had still good font. will test ingame
upd: yes seems like 280hz ingame monitor says 280hz and on desktop too
