Posted: 20 Aug 2021, 01:17
https://youtu.be/bTk0eCWDx4E give it a try guys
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
hiro wrote: ↑19 Aug 2021, 06:28Just had the electrician from the power company here and he had the device for testing with him for the weekend until monday. He already told me something is wrong when i switch devices on or off my Voltage changes to much it should Not do that he said. Lets hope its fixable they will come monday again to check what the device says.
same here please update us!alexander1986 wrote: ↑20 Aug 2021, 07:17hiro wrote: ↑19 Aug 2021, 06:28Just had the electrician from the power company here and he had the device for testing with him for the weekend until monday. He already told me something is wrong when i switch devices on or off my Voltage changes to much it should Not do that he said. Lets hope its fixable they will come monday again to check what the device says.
hey man, can you please give us a bit of details of what the electricians said, what they will be testing, what kind of device they are using to analyze and any other information about what they will do at your home?
I am asking because if they find problem and fix it, it will help every person that has this problem as we can then use that information to maybe get help from our power companies and so on you know,
good luck !
They testing with a fluke device like "FLUKE 434" not 100% sure and its plugged to every power phase what comes into the house they can see everthing related to power like Harmonics and Stuff its there since thursday until monday. When they cant fix it i probably give up...alexander1986 wrote: ↑20 Aug 2021, 07:17hiro wrote: ↑19 Aug 2021, 06:28Just had the electrician from the power company here and he had the device for testing with him for the weekend until monday. He already told me something is wrong when i switch devices on or off my Voltage changes to much it should Not do that he said. Lets hope its fixable they will come monday again to check what the device says.
good luck !
hiro wrote: ↑20 Aug 2021, 12:01They testing with a fluke device like "FLUKE 434" not 100% sure and its plugged to every power phase what comes into the house they can see everthing related to power like Harmonics and Stuff its there since thursday until monday. When they cant fix it i probably give up...alexander1986 wrote: ↑20 Aug 2021, 07:17hiro wrote: ↑19 Aug 2021, 06:28Just had the electrician from the power company here and he had the device for testing with him for the weekend until monday. He already told me something is wrong when i switch devices on or off my Voltage changes to much it should Not do that he said. Lets hope its fixable they will come monday again to check what the device says.
good luck !
How sure r u that ur issue is just electricity? Can it be isp related?alexander1986 wrote: ↑21 Aug 2021, 01:51hiro wrote: ↑20 Aug 2021, 12:01They testing with a fluke device like "FLUKE 434" not 100% sure and its plugged to every power phase what comes into the house they can see everthing related to power like Harmonics and Stuff its there since thursday until monday. When they cant fix it i probably give up...alexander1986 wrote: ↑20 Aug 2021, 07:17hiro wrote: ↑19 Aug 2021, 06:28Just had the electrician from the power company here and he had the device for testing with him for the weekend until monday. He already told me something is wrong when i switch devices on or off my Voltage changes to much it should Not do that he said. Lets hope its fixable they will come monday again to check what the device says.
good luck !
thanks a lot for the update, is there any chance you can take some pictures of all this stuff ? that would really help as well if someone wants to show examples to their own power company and so on !
and when they come back to you please try to ask them as much details as possible, I think if the source of the problem is in the building or at least close to you then you should be optimistic, if the source of the problem is further away then it could be tricky solution but still lets hope for the best !
anyway, again if you have time and energy to take some pictures of these devices and more detailed info about what exactly they are doing then it could really help everyone, thanks again !
