Currently I have the both settings off and get 200-270 FPS in Warzone.
noirguy
svd
Hello, I have a simple question,
Can I enable 280hz OC + 120 OD + ELMB all three together?
Also will it be simple or is it gonna be requiring more manipulation?
And if it's workable will it be normal or is it gonna have down side?
+ 8bit+FRC trick could this also work?
- axaro1
No you can't, ELMB will always force OD80.
Last time I tried it, the 8bit + FRC trick only worked up to 240hz.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
noirguy
rdkayy
Hi, can I get an update on the state of your monitor? Does it still work well or did you get a different one? I might be buying one of these, do you have any settings recommendations ?
- axaro1
OD60 280hz adaptive sync ON.
Alternatively, uncapped OD120 no adaptive sync.
*= currently owned
*= currently owned
CarloBlaine
Does anyone use the 240Hz 10 bit mode? Is it worth using or is the 280Hz OD120 8 bit better?
d4rthvdr
I have always wanted to ask the real owner of XL2546K.... how good for gaming VG279QM is if we compare it with XL2546K and even XL2566K ? can we say that this monitors have the same fast response ? Whos faster in games?
regards&cheers
- axaro1
It's fast, faster than most first gen 240hz 24.5"IPS but definitely not as fast as the 2546K/XL2566K or other top TNs like the Omen X25/XN253QX.
In 2024 I don't really see the point of getting the VG279QM when stuff like the XG2431, XG249CM and S2522HG exist + 27" 1080p PPI is an eyesore.
*= currently owned
*= currently owned
CarloBlaine
Does anyone know why with this monitor I never have a fixed fps, no matter how much I lock the fps it always jumps even though I have way more fps than it is locked to, for example in cod2 I have 1000, but if I lock it to 250 or 333 or 500 it never stays fixed but jumps. I use it at 280 hz and od120 with rting icc profile. Would it be better in 10bit 240hz, or does this have nothing to do with it?
Additionally, with a 60hz monitor with the same PC, the fps did not jump at all.
