External BFI Injection -- I am working with Retrotink 4K!
Re: External BFI Injection -- I am working with Retrotink 4K!
Post by Chief Blur Buster » 02 Oct 2026, 01:27
BFI wrote: ↑
07 Sep 2026, 23:29
The Tink 4K already supports this if you disable the low-framerate BFI limit, and adjust the BFI settings. You can have
For nativeHz:frameRate ratio of 120:30, you'd be able to do the following.
- 1 visible / 3 black
- 2 visible / 2 black
- 3 visible / 1 black
Unfortunately 30Hz BFI does flicker uncomfortably. Personally I'd rather tolerate framegen lag or tolerate 60fps than 30Hz BFI. However, I strongly advocated for the ability to do 30Hz BFI for integer-divisible refresh rates (60,90,120,150,180,210,240...) which you can all do with the Tink 4K.
However, it doesn't detect the unchanged frame of a 60Hz signal, so it's crapshoot whether you're getting 1 additional frame of latency or not. That frame-synchronization feature would be so niche as not to be worth supporting (Sadly), given the limited number of people willing to tolerate 30Hz BFI. (60Hz and 50Hz BFI is already flickery, but more tolerable).
I do not recommend 30 Hz BFI if you have not pre-tested it with other software.
You can test 30 Hz BFI using TestUFO at 120 Hz.
Flicker Warning for Photosensitive Individuals
1. Set your screen to 120Hz
2. I have a hidden test, http://testufo.com/bfi-photo ...
3. Configure to 1+3, 2+2, or 3+1 for Visible+Black. That 4-frame cadence gives you a 30Hz flicker at 120Hz.
4. Stare at it for like a few minutes.
5. See how you feel afterwards
Note: If you are stuck at 240Hz (e.g. monitor does not have a 120Hz preset in Control Panel), double up the numbers 2+6, 4+4 or 6+2 to simulate BFI adjustments at 120Hz.
Related note.
While DLSS/FSR/etc is generally useless (currently) for esports that already maintains high frame rates, this type of game (GTA6) generally isn't nearly as latency critical. GTA6 would be an excellent candidate for framegen.
Therefore, I recommend waiting for the PC version and using one of the higher-quality framegen algorithms that will be available by its release. The current state of art in framegen appears to be DLSS 4.5 and its 6x framegen feature, when the priority is blur busting with minimum AI slop (so avoid DLSS 5 if you're more interested in temporal fidelity over spatial fidelity)
Generally in non-latency-critical games, using the "framegen compromise" can even become the overall preferable blurbusting method (than 30Hz BFI) for CP2077/GTA6 type games that aren't as latency intensive as a competitive esports game. Especially if you're playing the single player story mode.
While the "AI slop framegen" and "neural rendering" is an ongoing debate -- A better-than-average framegen on a base 60fps frame rate, for this type of game (CP2077, GTA6, Witcher, etc) now tend to produce excellent results for a 240 Hz OLED as a more ergonomic blur busting alternative to BFI, since the artifacts:fun ratio leans heavily more fun than it used to be.
Interestingly for my most recent round of CP2077 (Liberty DLC playthrough for first time while using 5x framegen)...
...I even turned off DLSS scaling and used DLSS 100% just for framegen, when playing my last round of CP2077. The artifacts of "DLSS spatial only" versus "DLSS temporal only" actually had slightly less fakeness for about 80-90% of CP2077 motion. If you're already tolerating DLSS scaling, try turning off DLSS scaling (and turn off any enhancements like DLSS neural rendering), and using only DLSS framegen if you have a low-pixel-density 240Hz OLED. It ended up being preferable!
You often notice artifacts no matter what kind of DLSS, but I preferred to milk the Hz of my 240Hz+ OLEDs, and getting motion blur reduction via brute framerate, with RTX ON. So one tactic is no DLSS supersampling, but only DLSS framegen. Set the in-game cap to the pre-multiplier pre-DLSS framerate, with a headroom to avoid the lag-yoyo effect (of VRR framerates hitting maxHz). For example, ~57fps CP2077 cap for 240Hz OLEDs for 4x DLSS.
I would assume the experience would be (roughly) similar with GTA6, assuming the DLSS framegen model doesn't glitch with GTA6 imagery, given GTA6 is also an open-world game with a story mode, though it will also have an optional online multiplayer mode (not as latency critical as FPS shooters).
roginthemachine
Post by roginthemachine » 19 Oct 2026, 01:53
02 Oct 2026, 01:27
BFI wrote: ↑
07 Sep 2026, 23:29
Related note.
Hi chief, thanks for this helpful post. I just had a look now and even when I turn “min BFI limit” to off, I can’t get 30hz flicker working with a 60hz signal into the tink, and the tink sending 120hz output to the TV.
The strobe and blur settings can only go as high as “1” each
I think the OP was referring to a way to get 60hz signals displaying 30fps content to flicker at 30hz on the tink by instructing the tink to take two 60hz frames, and only dim the latter part of the second of these. Is there definitely a way to do this on the RT4K as is, when feeding it a 60hz signal? If so, can you advise how - as strobe and blur are stuck at 1 for me.
Or do we need to try and get the tink to “half” the PS5s signal by trying a custom 30hz modeline… if that’s something the tink can do?
Thanks so much!
Post by Chief Blur Buster » 19 Oct 2026, 22:33
roginthemachine wrote: ↑
19 Oct 2026, 01:53
Thanks so much!
You need to do it post-deinterlace.
You need to force the 60Hz signal to 30fps using 2:2 deinterlacing, or bob/weave algorithm. Once it's internally 30fps, you can adjust BFI, as far as I can understand it.
Step 1: Deinterlace 60i -> 30p (using 2:2, or bob/weave)
Step 2: Add BFI 30p -> 60p
You need internal retrotink fps to be half output Hz, before you can add BFI.
(Incidentially, that's how 96Hz can doublestrobe with 24p material after a 3:2 deinterlace step.)
BFI
Post by BFI » 11 Nov 2026, 22:50
Thanks for the updates Chief. Unfortunately I've not been able to get this working with my PS5, set to 1080i with the Tink outputting 1080p60. BFI shows N/A, while 2:2 remains 'Searching'. Bob shakes as expected so appears to be working, but again offers no BFI at 1080p60 with min limit turned off. Same deal with Weave.
Setting the output to 1080p120 returns BFI, but still locked to Strobe and Blur 1, and 2:2 remains searching. Possibly 480i is supported (for PS2 etc) but not 1080i?
Re: GTA6 I know that some people plan to run their consoles through capture cards for framegen, with the fastest cards reporting lag in the 30-40ms range. With rumours about a PC version in 2027 I think I'll just wait, since I'll be able to afford a relatively modest PC to run it at 1080p75 on my XG270.
19 Oct 2026, 01:53
You've got it!
With a PS5 set to 1080p (unlike the Xbox Series you can't force 120Hz so it defaults to 60), and the Tink set to 1080p120 with BFI Strobe and Blur at 1 (both limited to 1, like you say), you get double images with 30fps games that then look as bad or worse than native blur.
For 16.7ms MPRT with 60Hz flicker at 30fps the Tink would simply need to blank every second frame, instead of using the additional 60 frames of 120Hz to inject 8.3ms black frames after each original for 60fps content. But I think a smarter way of doing it for 30fps content (albeit a 60Hz input in this case) would be to utilise all 4 available steps at 120Hz, because in that way you'd have 4 x 8.3ms frames to either progressively dim or entirely blank to taste.
For example, 1:1:1:0 would be 25ms MPRT - 40fps equivalent - with low flicker. You could have 1:1:0:0 for 60fps equivalence with quite a bit of flicker (same as 1:0 at 60Hz with blanked second frames as above), or experiment with something like 1:1:0.5:0.
Post by Chief Blur Buster » 15 Nov 2026, 21:16
BFI wrote: ↑
11 Nov 2026, 22:50
By default, the Retrotink 4K's don't let you go low Hz.
Have you verified the low Hz BFI restriction has been turned off too?
BFI
Post by BFI » 17 Nov 2026, 03:44
Yeah, I'd definitely set Min BFI to Off. I forced my PS5 to 1080i to ensure an interlaced input for 2:2 or weave to convert to progressive, but couldn't increase strobe or blur above 1 at p60 or p120 output. I'm using genlock sync because it works on my three displays (framelock has resync issues on at least one of them). Firmware was a recent experimental - 1.99.12.
The Tink just seems to be expecting a 30Hz input for this p60 application, with i60 > p120 seemingly unsupported. Out of interest, is LCD saver recommended for an XG270 and LG C1? I'm guessing DLP mirrors are silver-backed and there's zero burn-in risk?
It's possible I've overlooked another setting change or combination thereof, but I don't know enough to try anything else so I'd be flailing in the dark. :lol:
