Re: ⚡Intel/AMD Fix desync, input lag, heavy car bug, etc *FINAL UPDATE*⚡
Posted: 22 Jan 2025, 11:47
1604 vs 1617 which is practically a margin of error, lolnaporitan wrote: ↑21 Jan 2025, 22:54Important information!
Some systems may not work correctly due to drivers from the official website of the motherboard!
symptoms: processor not reaching the stated frequency, ignoring bios settings and other various problems.
fix: clean install windows, update the system through windows settings and also set “optional drivers” in update settings.
and install the latest chipset driver from the official intel/amd website
example of a correct system:The latest version of the chipset driver from the official AMD website.
bench.pngThe update log should show the status of update installations as successful, and if there are errors, here is a recommendation for fixing them: Disable windows update service and go to C:Windows\SoftwareDistribution and delete everything inside that folder and run update check again.Stock version of the chipset driver from Microsoft servers.
@Z3CrosS is not telling ghost stories, but a real problem that can occur for various reasons and other/chipset drivers are one of them.
