Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
daviddave1
Re: Longstanding Floaty Aim Feel Issue Fixed with a Fiber Optic DisplayPort Cable...
Very interesting topic.
Just ordered a huaham HDMI 2.1. Fiber Optic from https://www.amazon.nl/dp/B0CYX1858V?ref ... title&th=1 for my 540hz Zowie Xl2586X
Also put my RAM on 1T 7400 instead of 2T 8000 for my DDR5 13900KS build . ( Doing some stabilizing testst atm) there are rumors though that my Gigabte Z790 AORUS TACHYON X
Mobo has a fake 1T setting? so its not real 1T? it wont boot on 1T 8000 so it has to be real right?
| Now: XG27AQNGV
akylen
If you have the problem , could you write here when it arrives if the cable did fixes something for you please ?daviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
JimCarry
does your pc boot on 8000 or not on any t ,and are you a cs2 pro ?daviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
daviddave1
Yes my pc boots on 2t 8000 and its stable. It does not boot on 1t 8000.JimCarry wrote: β15 Apr 2025, 22:07does your pc boot on 8000 or not on any t ,and are you a cs2 pro ?daviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
| Now: XG27AQNGV
daviddave1
I am not sure if I have the problem. But I will let you guys know if I feel a difference with the new cable.akylen wrote: β15 Apr 2025, 21:13If you have the problem , could you write here when it arrives if the cable did fixes something for you please ?daviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
| Now: XG27AQNGV
daviddave1
also it seems the Tachyon X Z790 does not support real 1t/1n Maybe gonna switch to the ASRock Z790I Lightning WiFi. Have to get some confirmations ASRock Z790I Lightning WiFi rreally supports it though... edit seems like u need apex, dark, unify or iedge for the Z790 platform.. checking now what board has the asmedia usb port and the non usb sound card...
seems like the DARK KINPIN is the only board that has that.
My eye has fallen now on the MEG Z690 UNIFY-X seems like it supports real 1N. Have to buy a MCU-based soundcard to get low audio latency to circumvent the ALC4080 card on it that is routed trough USB.
| Now: XG27AQNGV
daviddave1
do you have a recommendation for a 13900ks mobo that run TRUE 1T? Apparently my Z790 AORUS TACHYON X runs fake 1T and its hard to check the status of CMD_Stretch ( CMD Stretch messed with 1T so it becomes fake) on a intel cpu. Google and Chatgpt leaves me in the dark on how to check the actual status of CMD Stretch using rweverything. Do you maybe know how to check? If i dont get a confirmation my Z790 AORUS TACHYON X with A-die RAM runs true 1T or not I am gonna sell it for a MSI MEG Z690 UNIFY-X.kyube wrote: β03 Apr 2025, 18:44The rest is in fact important... lol
If his assumption was that the DisplayPort cable was a EMI source, then he doesn't eliminate it fully with these hybrid-optical fiber cables. He only dampens the effect, but there's still copper in those cables.
If his assumption was that the DisplayPort cable allows for conducted interference to enter his display, then it's not eliminated with these hybrid-optical fiber cables.
Anything past 3200β3600MHz 1T on Skylake gen Intel CPUs is unstable.
Anything past 6000-6600MHz 1T on Alder-Lake gen Intel CPUs is unstable.
These are numerical values which have been obtained from running various stress tests for extended periods.
To skip testing all of this testing, opt for QVL of mobo vendor (and hope they've done a good job testing the kits) or run EXPO/XMP disabled. Very simple setup.
| Now: XG27AQNGV
Randomguy007
I ordered the exact same cable, for me perfect gameplay now. I hope for you toodaviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
JimCarry
ok so you and op confirmed that this cable is working,very nice can someone give link for europe besides amazon link ?Randomguy007 wrote: β16 Apr 2025, 12:26I ordered the exact same cable, for me perfect gameplay now. I hope for you toodaviddave1 wrote: β15 Apr 2025, 20:19Very interesting topic.
iwabik
All of yours reports made me want to try this. I ordered the exact one from Amazon OP linked. I'm not having much hope as I believe the problem lies more in the game itself (CS2), but worst case scenario I'll just return it I guess, so why not give it a shot.
I will report when I get it, but it'll sadly be after Easter.
